New generator patent using environment temperature to generate power
Started by RedEagle, June 26, 2013, 01:24:04 AM
Do You Think this device will work?
Yes, definately
1 (10%)
Yes, but it needs changes
2 (20%)
not sure
4 (40%)
No, it can not work at all
3 (30%)
Total Members Voted: 10
Voting closed: June 29, 2014, 12:10:18 AM
Groundloop
Attached is a setup for testing the "Energy from using environment temperature to generate power".
I have NOT tested this myself but I see no reason that it could not be tested. Well, one is that you
need to carefully monitor the heat at the first (leftmost) junction of the two Peltier elements. This
junction must not exceed the maximum temperature that the devices can tolerate. You will need
to use a variable power supply for the input side of the two (left and right) Peltier elements, and
turn down the voltage of the power supply if this heat junction gets too hot.
The main question is: Will the COP of the heat transfer of the Peltier elements be enough to
compensate for the poor efficiencies of the elements them self? In sort, will the output from
the middle element be larger than the input to the two outer elements?
GL.
LibreEnergia
Quote from: profitis on July 03, 2013, 01:38:09 PM
@forest,the number of arrangements are almost infinite,the bottom line is a mirror is in fact a maxwell demon,in the dark,in the light,in a isothermal box,outside a isothermal box,evrywhere,anywhere.it can pump heat uphill for no expense.thats what makes it different from most heat pumps.
No, A mirror is not a Maxwell Demon. A Maxwell demon is able to (if such a thing existed) sort particles based on their energy state, thus creating and maintaining a temperature gradient where none existed before.  A mirror doesn't do that. It simply deflects radiant energy.
A mirror or lens cannot create a temperature that is hotter than the source temperature. The act of focusing radiation energy  does not decrease entropy overall.
profitis
@libre..wrong.a mirror the size of the sun aimed at the sun would increase its temperature,thus making it hotter than the source,thus decreasing its entropy spontaneously,thus working against the 2nd law.a maxwell demon does not have to be active to sort energy states.it can be totally passive and still do this.
