Thanks to ALL for your help!!
How to get energy from resonance
Started by Johny70, June 28, 2013, 05:25:11 AM
Jeg
Quote from: vasik041 on March 30, 2014, 12:58:44 PM
You can try WIMA capacitors, they are quite good.
But you still need put several of them in parallel...
Thanks a lot. I'll try to locate them. I have to say that even I managed to tune the secondary in a classical don smith arrangement, no overunity results occurred. I give 22watts on primary and I light a neon bulb of 11watts very very brightly. When I connect a second 11w load, the system can not power them correctly. After rectification on secondary side I charge a cap of 15μF at 500v (perhaps needs more capacity). I connect the light in parallel to the capacitor and in resonance the voltage goes to 250v with full bright at the load. I think that ground needs more consideration as I only use one ground rod with 1.5mm2 cable connecting it to the system. I will also try to produce a positive feedback to see what happens. I wonder what will also happen if I tune more secondary's in a Hubbard arraignment style. Anyway, just thoughts... but... ground is a real issue to consider...
Tnks
Jeg
vasik041
Hi Jeg,
I don't want disappoint you...but so far nobody was able replicate this device.
Even more, according to my understanding it should not work as decribed.
If you extract power from resonance circuit you "kill" resonance.
(Ferroresonance does not make any difference)
I am not saying that it does not worth experimenting. It still very nice educational toy.
Wish you luck :-)
Jeg
Thanks vasik041 :)
I do this for fun anyway, and for sure it is a good educational toy!
I see in Don's circuit, 3 vertical coils around a single transmitter. They are in a distance between each other. I think that they are in a 1/4 wavelength distance. With this arrangement perhaps the power transfer is Lenzless. Will see...
Google
Quote from: Johny70 on June 28, 2013, 05:25:11 AM
I made resonant transformer (BOCAF, transvereter) and get nice saturated core with high voltage from resonance (~400V, input 25V/200mA) in secondary coil. I tried to build circuit for drawing energy from resonated coil (shown on many web sites, with capacitors, transistors, SCR, ...) but they don't work. Resonance stop whenever I try to get even a mA from it.
Question: Does anybody built a circuit for drawing energy from resonated coil?
Thanks in advance,
Johny
PS Sorry if I missed some post with similar answer.
Hi Johny,
Please check this one out, may help.
http://marblar.com/technology/US8110949
Only one kind request. Please share your results. Its a common disease  on free energy forums that once people get positive results, either they vanish or they keep mum.  ;D
Best,
Google
Johny,
Please also try this configuration described in Tesla patent for some unexpected and astonishing results that may actually shock you to the core, defying the laws of energy conservation. I am saying it without saying it.  :o
https://www.google.com/patents/US593138
By the way, this is the most overlooked of the Tesla patents and the same principle is being used by some people from Georgia, demonstrating free energy generation.
Best,
