Thanks to ALL for your help!!
Aether Displacement
Started by mpc755, July 01, 2013, 09:39:13 PM
tinu
 @ mpc755,
Interesting thoughts!
Please expand on "Displaced aether pushing back and exerting inward pressure toward matter" and how exactly it can lead to generally/qualitatively explaining (and, if possible, quantitatively describing) gravity. I'm thinking in particular at Kepler's laws (including the 'infinite propagation speed') but also to the problem of three aligned bodies that any theory of gravity as a pressure force is having issues in dealing with it.
As for double split experiment, please develop on the action of the associated wave upon a particle exiting from a slit, the same particle that generated the wave in the first place. Is the associated wave reflected by matter? What would be the laws of propagation for those waves? I would be happy to hear your answer in the good&simple boat-wave analogy but keeping in mind that the analogy can not ultimately hold water since a particle/photon etc. could not emit continuous energetic waves without slowing down (or could it?).
Best regards,
Tinu
mpc755
Quote from: profitis on July 25, 2013, 10:53:28 AM
aha @mpc..aether displacement is one of many ways to perceive reality,sure,but it might have shortcomings.
Aether displacement is the most correct way to perceive reality to date. As correct as perceiving reality as Earth rotates on its axis and orbits the Sun.
Quotean interesting test might be to shoot  electrons at a double slit and see if we get similar results to steinberg.
Of course we will. The stronger you detect the particle the stronger you destroy the coherence between the particle and its associated aether displacement wave.
In a boat double slit experiment the boat travels through a single slit and the bow wave passes through both. As the bow wave exits the slits it creates wave interference which alters the direction the boat travels. Placing pylons at the exits to the slits knocks the boat around and cuts the bow wave into smaller, choppier waves. The coherence between the boat and its bow wave is lost and the boat continues along in the general direction it had been.
mpc755
Quote from: tinu on July 25, 2013, 01:34:34 PM
@ mpc755,
http://en.wikipedia.org/wiki/Casimir_effect#Vacuum_energy
"a "field" in physics may be envisioned as if space were filled with interconnected vibrating balls and springs, and the strength of the field can be visualized as the displacement of a ball from its rest position"
A 'field' in physics is space filled with aether and the strength of the field is the displacement of the aether from its rest position.
Each of the plates in the Casimir effect displace the aether. The displaced aether which exists between the plates is pushing back toward each of the plates which causes the force associated with the aether displaced by each of the plates which exists between the plates to offset. This aether is more at rest than the aether which is displaced by the plates which encompasses the plates. The reduced force associated with the aether which exists between the plates along with the displaced aether which encompasses the plates which is pushing back and exerting inward pressure toward the plates causes the plates to be forced together.
What occurs physically in nature in the Casimir effect is the same phenomenon as gravity.
There is no such thing as non-baryonic dark matter anchored to matter. Aether has mass and physically occupies three dimensional space. Aether is physically displaced by matter.
Displaced aether pushing back and exerting inward pressure toward matter is gravity.
The following are the two best articles I have found. I have a bunch of other articles I found at arxiv.org which discuss gravitational aether. I can post those if you would like.
'Comment on the higher derivative Lagrangians in relativistic theory'
http://arxiv.org/pdf/1305.5759.pdf
"The relativistic theory of an Aether was discussed several time, see for e.g. [8], [9]. In this paper, our hypothesis is different and gives a relativistic theory of the deformation of continuous media (for which the geometry is described by the metric field)."
The Milky Way's halo is the deformation of continuous media. The Milky Way's halo is curved spacetime. The Milky Way's halo is evidence of the correctness of relativity. The Milky Way's halo is the state of displacement of the aether.
'Fluidic Electrodynamics: On parallels between electromagnetic and fluidic inertia'
http://arxiv.org/abs/1202.4611
"It is shown that the force exerted on a particle by an ideal fluid produces two effects: i) resistance to acceleration and, ii) an increase of mass with velocity. ... The interaction between the particle and the entrained space flow gives rise to the observed properties of inertia and the relativistic increase of mass. ... Accordingly, in this framework the non resistance of a particle in uniform motion through an ideal fluid (D'Alembert's paradox) corresponds to Newton's first law. The law of inertia suggests that the physical vacuum can be modeled as an ideal fluid, agreeing with the space-time ideal fluid approach from general relativity."
The relativistic mass of an object is the mass of the object and the mass of the aether connected to and neighboring the object which is displaced by the object. The faster an object moves with respect to the state of the aether in which it exists the greater the displacement of the aether by the object the greater the relativistic mass of the object.
The relativistic mass of the Milky Way is the mass of the Milky Way and the mass of the aether connected to and neighboring the Milky Way which is displaced by the matter the Milky Way consists of.
The relativistic mass of the Milky Way accounts for the speed at which the matter in the Milky Way moves.
QuoteAs for double split experiment, please develop on the action of the associated wave upon a particle exiting from a slit, the same particle that generated the wave in the first place. Is the associated wave reflected by matter? What would be the laws of propagation for those waves? I would be happy to hear your answer in the good&simple boat-wave analogy but keeping in mind that the analogy can not ultimately hold water since a particle/photon etc. could not emit continuous energetic waves without slowing down (or could it?).
Best regards,
Tinu
The aether is, or behaves similar to, a supersolid.
Q. Does the particle displace the aether or does the aether displace the particle?
A. Both occur simultaneously with equal force.
'Interpretation of quantum mechanics by the double solution theory - Louis de BROGLIE'
http://aflb.ensmp.fr/AFLB-classiques/aflb124p001.pdf
"When in 1923-1924 I had my first ideas about Wave Mechanics I was looking for a truly concrete physical image, valid for all particles, of the wave and particle coexistence discovered by Albert Einstein in his "Theory of light quanta". I had no doubt whatsoever about the physical reality of waves and particles."
"any particle, even isolated, has to be imagined as in continuous "energetic contact" with a hidden medium"
The hidden medium of de Broglie wave mechanics is the aether. The "energetic contact" is the state of displacement of the aether.
"For me, the particle, precisely located in space at every instant, forms on the v wave a small region of high energy concentration, which may be likened in a first approximation, to a moving singularity."
A particle is a moving singularity which has an associated aether displacement wave.
In a double slit experiment the particle travels a well defined path which takes it through one slit. The associated wave in the aether passes through both. As the aether wave exits the slits it creates wave interference. As the particle exits a single slit the direction it travels is altered by the wave interference. This is the wave piloting the particle of pilot-wave theory. Detecting the particle strongly exiting a single slit destroys the coherence between the particle and its associated wave in the aether.
What ripples when galaxy clusters collide is what waves in a double slit experiment; the aether.
Einstein's gravitational wave is de Broglie's pilot-wave. Both are waves in the aether.
mpc755
'Astronomers create largest map yet of dark matter's web'
http://www.today.com/id/45928302/ns/today-today_tech/t/astronomers-create-largest-map-yet-dark-matters-web/
""It is fascinating to be able to 'see' the dark matter using space-time distortion," said Ludovic Van Waerbeke of the University of British Columbia."
Ludovic is close to correctly understanding what occurs physically in nature.
Dark matter is not using space-time distortion. Dark matter is the space-time distortion.
Aether has mass, physically occupies three dimensional space and is physically displaced by particles of matter.
Space-time distortion is referred to in the following article as the deformation of continuous media.
The Milky Way's halo is the deformation of continuous media. The Milky Way's halo is the distortion of space-time. The Milky Way's halo is evidence of the correctness of relativity. The Milky Way's halo is the state of displacement of the aether.
mpc755
Quote from: mpc755 on August 07, 2013, 12:18:34 PM
Dark matter is what is being distorted. Otherwise known as the aether. Aether has mass.
