Bedini, Lindemann, Bearden, Dollard -- What are their Accomplishments?
Started by Ein~+ein, July 04, 2013, 10:57:50 PM
tinman
Quote from: Ein~+ein on August 19, 2013, 12:55:14 PM
You say 'mostly copy and paste' from the internet?  That may be grounds for copyright violation unless permission was granted or the copyright has expired.  The copyright holder must also be willing to take them to court.  As I'd mentioned in a previous post, there was an attempt to launch a class action suit against them (on another thread here)...if anyone cares to resurrect it.
See what I mean about Aaron discrediting himself better than anyone else could?: "You have caused trouble around here for quite some time just because you lack the skills to get anything to work right."  If Aaron, Bedini, or anyone else on that forum is incapable of stepping you through what's required to get something to work, why wouldn't they offer to do it for you for a fee?  They are in business, are they not?  I mean, if Ikea only sold plans in books for their furniture, they'd have less than 1% of their business and who'd look incompetent if no could properly assemble their furniture.
Yes-tesla and cromrey aswell-over 20 pages of copy/paste from the net on these two. Both pictures ( a couple of examples below) and many pages of there patents.Now i would find it hard to believe that they could have had tesla's permision-for ovious reasons.
tinman
If you are new to pulse motors,and are going to build the standard SSG-know that if built the way JB describe's,you have just built the worst possible configuration.If you make it so as the coil end that faces the rotor magnets,is fireing a north field,and the rotor also has the north field's facing out,your soft iron(steel rod) core will become magnetised,and the efficiency of the motor will slowly degrade.
There is two simple fixes for this.
1-reverse the polarity of both the run coil,and trigger coil,so as your motor become's an attraction motor.The coil will then be fireing a south field at the rotor end,and the rotor magnets remain north.This will help stop the core becoming magnetised.
2-Simply turn the magnets around on the rotor,so as the south field faces out,while leaving the coil as is(standard ssg)
Another improvment i have found is-dont rap your two wires on together. First wind the trigger coil on (.4-.5mm wire is best for 12 volts)Dont worry to much about how many turn's,just wind on 4 layers as neat as possable.Then use thread tape,and lay on one layer of thread tape over the trigger coil. Then 8 layer's of .6 or .71mm wire over the top. Make your coil core 3/4 inch by 2 1/2-3 inches long. Use 1/2 inch wide x 3/4 inch long neo magnet's in the rotor.
If using a lot of magnets in the rotor that will be closer than 2 inches together-alternate the fields N/S/N/S. This will insure the transistor switches cleanly,and will run cold.
Mmm-maybe i should write my own book,on how to build a decent machine lol.
Ein~+ein
@Tinman:
It continually baffles me why anyone would invest time and expense into attempting to build something that defies the known laws of physics merely because someone says you can.  As I understand it, it's more than just ignorance or the desire to become rich or famous, it's about the almost-religious belief in suppression conspiracies and aliens as this thread I started suggests.  There's a Don Smith device thread on EnergeticForum with over a million views and nearly 10,000 posts.  One would think the conversation would be well into manufacturing or marketing by now, but like virtually every other FE device, it's still stuck in proof of concept stage.
If it was merely about making money I'd borrow money to buy and sell currencies or stocks in flux.
profitis
lol @einstein.it baffles you because there is a possibility that they can do exactly that.
Ein~+ein
Quote from: profitis on August 20, 2013, 04:06:21 PM
I'm not following your line of reasoning---if I thought there was a possibility, why would I be baffled?
