New Rosemary Ainslie Demonstration Scheduled for Sunday, 4 August 2013
Started by TinselKoala, July 29, 2013, 03:48:24 AM
WILL YOU PLEASE PERFORM THE OPEN CIRCUIT FG MEASUREMENT, and then LEAVE THE SETTINGS ALONE !!!!
This is insane. You do not know the FG settings, you do NOT know the contribution of the FG since the settings have been changed to some unknown value!
You need to do what is listed in the Protocol document, with the exception that the FG open circuit settings must be measured at the beginning, recorded and reported, and then locked down!!! This is BASIC experimental technique!
Without knowing the precise FG settings and the power contribution, the rest of the "demonstration" is essentially useless. Especially if you call the thing off and don't even wind up making the open-circuit measurement, as you apparently did yesterday.
"I can see the meter, don't move the camera away.. WHY Are you moving the camera away?...."
Because they are incompetent and can't even follow directions as well as an eighth-grader might.
DO NOT FORGET PHASE 5. If you go through all this and fail to make the opencircuit FG measurement.... then all of this is USELESS.
The readings you get are strongly dependent on the FG OFFSET and THIS MUST BE KNOWN from an open circuit measurement!!!!!!!
It takes two minutes!
NOOOOOOOOOOO.........
You've cut off the demo without the MOST IMPORTANT PIECE OF DATA !!!!!!!!!
I am astounded. You lot should be ashamed. YOU DID NOT FOLLOW YOUR OWN PUBLISHED PROTOCOLS IN EITHER YESTERDAY OR TODAY.
WE STILL DO NOT KNOW THE FG OPEN CIRCUIT SETTINGS OR THE POWER CONTRIBUTION OF THE FG.
