Magnetically Imbalanced Wheel
Started by Hope, August 09, 2013, 01:58:22 AM
profitis
totaly wrong @libre.if you hang one of those upconversion devices from foreverlight.com in a isothermal box it creates a temperature gradient,in theory and in practice.the electrochemistry example is straight from the textbooks so your daughter will have to prove that the text-books are wrong when they say that an oxygen electrode potential is dependant upon oxygen coverage of a platinum electrode,she wont be able to dispute this fact in theory or in practice.
Hope
Ok this is the disk being built.  My resolution is far to high so I will have to reshoot the photos.   Thanks Gadgetmall for the insight and positive comments in your PM to me.
LE  thanks for your comments, please take the time to understand the model presented.  We are not obtaining torque movement from repulsion of magnetic fields.  Instead we are magnetically imbalancing a wheel and allowing gravity to attempt to rebalance the device.  The disk is kept in constant imbalance therefore gravity will keep the wheel turning.
LibreEnergia
Quote from: Hope on August 20, 2013, 09:25:49 PM
This is exactly what I am referring to, and I fully understand this device. I predict you will shortly discover it does not work.
I'm simply pointing out why. You cannot combine conservative forces in such a way that gives rise to non conservative result, as would be necessary for this machine (or any other of this kind) to produce usable net work output.
profitis
dont listen to libre @hope.he has failed to uphold the thermo laws regarding light,electrochemistry and gravity,and therefore we cannot exclude magnetism.
Hope
Have to put brakes on the vehicle tonight so I will take some lower resolution photos and post them tomorrow.  The build is coming along fine.   I did find that the magnets NOT on the disk must be mounted on the opposite side of the metal (perhaps non-ferrous) that shown in the drawings.
LE if we do not try every way the how for certain can we eliminate all possibilities.  Without trying we may miss what could work.
Can you show your efforts, we would like to see them.
