Magnetically Imbalanced Wheel
Started by Hope, August 09, 2013, 01:58:22 AM
ingyenenergiagep
Use magnetic balls. South pole inside, North pole outside.
Hope
That is the idea in a way,  the weights must be axis centered then when repulsed the will move beyond the center.  This is great because the weights in the center can be heavy and will make the power amplified over my orginal thoughts.
the return of the heavier weights can be repulsed also.
Hope
Also the rods will not flex and the will push the axis weights to the counter balance side, revisions happen unless you are Tesla.    This project is getting better all the time.  I envision a long axle with a cylinder supported with spokes and the weights on the axis being repulsed to the opposite side to make imbalance.  This is actually easier than the original design.  Hopefully I can contact Sean for his thoughts.
Your comments and PM's are greatly appreciated.  This project is moving along well,  thank you.
Hope
Tubes mounted thru an axle hub from one side to the other with ball bearings just might be quite simple to prototype.   What I am needing is more weight on the down going side.   I think this design will work both directions by simply starting the rotation either direction.  Can someone model this as a simulation?  Thanks
truesearch
@Hope
Unfortunately, I'm not experienced enough with any magnetic-sim to do anything  :(
truesearch
