Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Bob Smith
FWIW,
YT user Hibridor's newest video
https://www.youtube.com/watch?v=MtIdTQWkCuM
Translation:
28 sec: (Image of VLC SLIM)
- "The device is a suppressor of high tension spikes used as a "pararayos" (lightning conductor/rod). Technically, it is a spark gap."
39 sec: (Image of Kapanadze [Kapagen(?)] windings)
- "Spark gap"
   "Kapanadze generator"
44 sec:
- "1. In the primary winding the tension is elevated thanks to the closed loop."
50 sec:
- " The VLC SLIM discharges the (high tension) surge towards the ground"
55sec:
- "The process repeats itself continuously generating a constant pulsing."
1:00:
- "!!!A spark gap!!! -SG- This is how power is gained.
   The Kapanadze/Tesla technique."
skribat
Quote from: Bob Smith on February 08, 2015, 10:30:10 AM
Hi Skribat
Glad to help in a small way. My interest is in identifying the central principle(s) involved. As you say, there seems to be elements in common with TK's work, and I'm sure there are others.  The patent notes that this B&L technology can be used "to trap electrons from space" as well to "extract electrons from the earth." See page 33, first paragraph here:
http://www.free-energy-info.com/Chapter3.pdf
I believe this is basically what Moray was doing - starting with pulling a charge out of the earth, then later adapting his setup to use a kind of virtual ground. Bearing that in mind then, what is it that this system is actually doing?  Is it perhaps more in the nature of exciting the electrostatic environment and creating a kind of gradient of charge imbalance/separation which invites nature to supply charges to restore what the environment perceives as an imbalance?
In my mind, if we can figure out this principle and how to apply it in a variety of different modalities (solid state, mechanical and hybrid combinations), we can effectively blow open a door with huge possibilities - one that can't be closed.
Bob
hi bob thakyou for that it made very interesting reading .. right down to the much ignored ,, vibrator ..  ' magnetic pulse generator' ? ..  there is also a striking resemblence to the Lutec magnetic motor / generator which you may know about, patents have been granted in more than 60 countries .. same technology as far as I can ascertain. ..  you can search youtube for the Jan2015 upload, the Lutec website was taken down when they entered into negotiations with (reportedly) a Singapore company ? one year ago .. sk
skribat
Quote from: Bob Smith on February 08, 2015, 11:47:42 AM
FWIW,
Translation:
- "Spark gap"
44 sec:
50 sec:
55sec:
1:00:
I love when a plan comes together .. well done ..sk
Bob Smith
Here's my question:
With a lower powered system (ie., much lower than mains), could we employ a zener diode in place of the VLC SLIM to get the same kind of pulsing action?
Bob
Clarence
Quote from: Void on February 04, 2015, 12:13:55 PM
Hi Clarence. Thanks for the update. Ok on you being the only farmhand. ;)
Take your time mate. Rushing at this sort of stuff does not help anything.
If it is kind of swampy out in your neck of the woods then that may mean that
you should have quite good potential conditions for getting a really good earth ground.
All the best...
Clarence:
Hello Void, a,king21, Spokane, & ALL,
This is the update on my B&L exact replication build with its improved GROUND GRID SYSTEM that I promised.
All of the news is GOOD news. bear in mind that I tested having my tripp lite PR30 powered by mains voltage ONLY
for this TESTING PURPOSE ONLY!!!!! NO mains voltage of ANY form will be used in my completed successful build!!!
any so-called replication build using any form of mains power in a completed build IS NOT A REPLICATION OF THE B&L DEVICE
- it is just bull shit.
1. the last time I tested before the improvement of the NEEDED ground grid system the return from the ground rods only produced
    a low voltage system voltage of 84 to 90 volts. I'll say just 84 volts (chose the lower). and that was using my PR15  tripp lite by means of the
    system circuit voltage which low voltage quickly burnt it up.
2. this time being cautious I tested by powering my new PR30  power supply from mains voltage, AGAIN I NEED TO SAY
     ....ONLY .... for testing purpose!!!!
    this time the new 8 rod open ended ring lit the 250 watt red heat bulb at 200 watts with a system circuit voltage of 110.7 volts.
    YES! an improvement!!!!!!!!!
3. being further curious AND CAUTIOUS I disconnected  the PR30 from mains supply and hooked it instead in the system circuit supply.
    without ANY test bulb plugged in. I wanted to see what the power supply load itself would do to the supply from the ground circuit voltage
    so with my finger kept on the power switch I turned the power supply on and the UNLOADED circuit supply voltage of 116.2 volts quickly
    dropped and settled out at 103.2 volts.I quickly hit the PR30 switch and shut it off so as not to damage it also.
All in all this improved ground system just says what this whole device is all about. AGAIN - ENERGY FROM THE GROUND!
at this point I have NO doubts that the B&L device AS shown in the patent language and drawings IS A VIABLE DEVICE!
when a SUFFICIENT ground grid is provided it will work as they stated!!!!!
they just may have not stressed the point about the magnitude of the grid system required.
In their country their system is a 220 volt system and definitely would require a LARGE GRID! especially a three phase system!
my system is a single phase system and 120/240 volts so a smaller GRID would suffice.
I also have been shown that the size of the GRID has to have ENOUGH BACKUP POTENTIAL so that system loads are not using up potential
FASTER than it can be RECEIVED!!!!
with this in mind in the next two weeks I am going to add 6 more rods to my system as I want to continue with the GRID size until I am able to
Power the 250 watt bulb with the power supply being IN the system circuit voltage and NOT ANY mains  voltage!!!
ONWARD!
thanks and cheers!
Clarence
