Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 31 Guests are viewing this topic.
wistiti
Hi guys!
One other question.
What is the spect of the ground rod (lenght, diameter and material...)
Thank again!
Clarence
Quote from: wistiti on March 31, 2015, 01:22:55 PM
Hi guys!
One other question.
Thank again!
Hello wistiti,
glad to answer sir,
the rods are called copper bonded ground rods.
they are 8 foot long.
they are 5/8 inch diameter.
any local hardware should stock them.
you will need to get one of the brass oblong 5/8 diameter wire clamps to go with each rod.
I have attached a photo to show what I am doing with them.
cheers
Clarence
wistiti
Thank you Clarence!
Again, it is a clear answer. :)
Where I live (Canada) we have to wait until the end of April, maybe May before the snow leaves the ground...
But I learn by building and I will surely give it a try!
Please continue to let us know about your findings.
Sincerly!
Enjoykin
Hello old man Clarence :)
What a nice copper rods for primary of Big Tesla Transformer. :)
Why don't you build one, and make Lahovsky coil for health treatment !!
You are really prospecting for Tesla Telluric Currents isn't you?? Is it your case i think you shoud break symmetry of equidistant potentials in Iowa ground. Simple - spark it up - spark ground - strike it strongly !!
Make a strong arc sparks using welding machine and see yourself. This is a real setup of professional welder with his experiment in which he was shocked with very high current keeping in one of his hands heavy amps welding cable well insulated while sparking transformer with other hand(glove) with welding electrode. Current shock has blocked his arm long time after strike. He has lucky and his both arms are OK.
In my oppinion Barbosa and Leal for sure have some kind of spark gap/s and for sure did high voltage or high current sparking of their Tor transformer. Try it maybe you have a luck !!
ps: Don't keep heavy amps cable in your hands !!
Regs from Russia.
Enjoykin
Clarence
Quote from: Enjoykin on April 01, 2015, 11:47:21 PM
Regs from Russia.
Enjoykin
HA!  HA!  HA!
1. their is absolutely NO spark gap nor ANY necessity for one in this build.
2. I have SUCCESS in this build their is no need for any  waste such as so called luck.
3. I am presently using my build to power some of my common house hold appliances that I  choose!
NUFF
Clarence
