Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 93 Guests are viewing this topic.
Enjoykin
Quote from: Clarence on April 02, 2015, 05:18:27 AM
HA!  HA!  HA!
1. their is absolutely NO spark gap nor ANY necessity for one in this build.
2. I have SUCCESS in this build their is no need for any  waste such as so called luck.
3. I am presently using my build to power some of my common house hold appliances that I  choose!
NUFF
Clarence
Hello old man  :D
HA HA !!
Loop it - Loop your build without accum.battery and battery charger. Show us OU !!
Rectify output and power-up your inverter  !! Show us Self-Runner - and you will be OU-Hero in Iowa and U.S. :D  Record a video of your build.
If you are using your accum.batterfy how much long can your build run with maximum load ??
1hour ?? 10 hours ?? 31 days ??
Reg.
ramset
Clarence,
Yes please try to loop or not be attached to your house mains in any way.
I had an experience several years back with an open source OU water heater project [sonic boiler]
which I could not get working properly I was doing a verification/replication for some one in Europe and then he told me I had to put outside ground rods like you are doing ,but one side connected to
my house mains.
I had a very bad feeling that this was not really OU and dropped that path.
seemed like I was actually doing something like this,
https://en.wikipedia.org/wiki/Single-wire_earth_return
as I recall he told me to wet the ground rods too..
if it turns out you are truly tapping energy that no one else is paying for
I will share the details of that experiment here [MUCH simpler]
respectfully
ChetKremens@Gmail.com
Thanks Grandma
e2matrix
Quote from: Clarence on April 02, 2015, 10:28:59 AM
Hello cheors & ALL,
to be blunt - NO! been there done that!!!!  P-POOR results!!!!!
The BEST AND ONLY GOOD RESULTS nowdays strictly come from using ferrite  toroid transformers.
I have noticed on this thread that MANY members want to try to use a heapy-cheapy way real quick to try and "GET SOMETHING DONE" .
all they accomplish is shooting themselves in the "FOOT"!!!!!!
It is NOT " my way or the highway attitude " is  simply a case of reality!!!!
the INHEIRENT  values within the ferrite toroid IS what produces the RESULTS everyone is looking for!!!!
I just can not seem to get the point across to members for some reason.... its beyond me why? ???
B&L THEMSELVES used a TOROID even though at first it was a salvaged IRON core toroid they then wound themselves!!!!!
PURPOSELY I have stayed as exactly as close as I could get to B&L's desisgn so I could achieve like results!!  AND I have.
stay as very close to my unit and you will have their same results!!!!  deviate as you will and know you are going to have the effect of SHOOTING
YOURSEL IN THE FOOT!!!!!
Whatever! HOWEVER I am mindful that you ASKED! and that is the reason I have been BLUNT! I would ALWAYS rather try to HELP someone who asks for help.
thanks to you sir and cheers!
Clarence
Good stuff Clarence - love the replies and your mindset on all this.   It is likely a good part of why you are having success with this.
  A little thought on putting those copper rods in the ground ....   Not sure how you are getting them into the ground unless it is with your farm machinery but the last time I put an 8 foot rod in ground it took me an hour of pounding with a 6 pound sledge.   One suggestion I was able to use another time may help as long as you have a good water supply (I didn't have that when I had to pound it into the ground) :  get a 8 or 10 foot piece of 3/4" sch. 40 pvc pipe and PVC glue adapters on it so you can attach it to a hose.   Put a cap on the other end with a hole in it (or you may try without one) and turn on the hose full pressure to make yourself a water drill.   It worked quite well the time I tried it.   Forget it though if you are in California  ;)
Enjoykin
Hey old man Clarence !!
This is a snapshoot from video i have took last year from Tube from some Serbian guy who has succesfully replicated Barbosa and Leal OU-generator. He got OU 43. I took 4 videos. His channel was wiped-out very soon after his last video. What's happened with him i don't know. Maybe he was also wiped.
This is his explanation about Barbosa transformer.:
"Heating via Barbosa transformer. Heater power is 2150W and consumption from the mains 49.5 W. Note that the scalar reverse Tesla coil and the impact on the climate and the living world around him, not yet examined. This scalar device draws free electrons from the land and resonance multiply their number by the rising strength of the stretch marks on the output device. "
He used only one big Ferrite Tor transformer.
Old man why don't you try his setup ??
ps: Looking this and many similar buids i thinik that Oz-guy Chris Sykes (hyiq.org) was right about opposite coils (partnered coils) in his explanation as a source of Scalar Magnetic Field. 2nd field was officialy classified as secret - because is a SOURCE OF FREE ENERGY. Remember that Professor Stevan Marinov has been killed in Austria few days before International conference in Germany about Scalar Fields and presentation of his OU-Marinov motor.
ps2:
What is very interesting is 100% builds use ferrite transformers - many Tor shape and others EI shape. Does it work with soft iron, steel, copper, bronze, silver, gold and other metals - instead ferrite cores ??
Barbosa and Leal generator  - 4 videos for analysis
Доступен до: 2015-05-02 19:25:59
Ссылка для скачивания файла:
http://rusfolder.com/43367351
mrzlica
Hi Enjoyjin!
This is not true , the man did a false power reading. >:(
I know people visit him, leavingthe place with long face!
Ther was no loop device in Serbia, this particular you are showing was not!
He wipe the channel because it was not a working one.
