Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Hoppy
Quote from: skribat on April 04, 2015, 07:35:05 AM
I agree with you ..  'remove the resistance'  assume it can be done ..  even if it couldn't self-run .. wouldn't you be happy if it just halved your electricity bill ..  I think Clarence is an honest guy with every intention of sharing the results of his hard work . .. this is no time to be standing on the guy's face when he is trying to drag us up off the ground. .. Let's not argue OU  it doesn't matter if it is or not at this point,  let's just see how much progress has actually been made and be grateful for it. Little by little we are moving forward, it often takes a while.  It took ants five years to undermine my gatepost but it eventually fell down.  Let's all get behind Clarence and give him as much support as we can. if it were to fail we lose what .. nothing, if he succeeds we have a lot to gain. Other people in the past have failed because they didn't have enough support to prevent big business taking them out of the game, we can't let it happen again.
There is a difference between being deliberately obstructive and making comments that might appear to be negative but given with the best intention, so as to help Clarence to determine if his device is truly self-running. I consider this to be valid support.
shylo
Enjoykin
Quote from: a.king21 on April 04, 2015, 06:08:11 AM
And iron boats will never float. Everyone knows that.
Hello a.king21  :D
Why don't you take some trip to Iowa and do some measurements ?? Give old man 5 000- 6 000 bucks and make a tests - but not like you did in case of Kapanadze - 20 000 bucks for 2 hours show and nothing ??
About oldman setup - honestly what is for me particulary very interesting is Partnered Toroid configuration. Drawn schematics are not correct because secondaries of Toroid transformers are in antiphase with crosspoint virtually grounded via captor. As a matter of fact it is the only configuartion which is able to produce powerfull scalar field. All of that is Tesla Technology. Two coils at same wavequide lambda/4 resonance  both in antiphase (180 electrical degrees) both grounded on cold end with heavy copper conductor. Same configuration many people made like in Clarence case. For mighty power extraction Tesla scalar need very big mass of copper (or other good conductors). When we strike two B-fileds (with opposite propagation vectors) we can't destroy both but we transform them in powerfull Scalar (longitudinal wave) with own power as sum of both B-fileds. What we do is Scalar reconnection of field lines at both vector fileds. Two very strong B-fileds (opposite each other ) when collide - transform in Scalar field. Keep in mind Scalar field haven't electrical nature and can't be meassured directly with known tech.equipment. Cold currents and other anomalies are direct Scalar filed aftereffects.
Looking from Tesla world outlook -  currents as electrical temperatures - we have two temperatures. Hot ( vector currents) and Cold (Scalar currents). Crosspoint of two B-fileds behave as very Cold point while all other ponts like copper rods in ground are very Hot. As much as we can cool down crosspoint (rising Scalar potential) automatical we rise all Hot points (vector potential of cooper rods). To balance this anomaly Hot temperature will start flow in mighty stream to Cold point. This massive impulses of free electrons (energy waves) come from the ground to crosspoint and warm up (balance) anomaly. It affect reciprocally as rising electricity (hot temperature) in system and we see it as Over Unity.
ps: Properly tunned Tesla Transformers cold down when operarte, Floyhd Sweet VTA cold down etc.. Interesting facts isn;t it
ps2: Don't consider Tesla "electrical temperatures" as adiabatic "thermodynamic" temperatures. They are not the same nature. (for example like solid ice and plasma)
Reg.
Enjoykin !!
a.king21
Enjoykon:  What I learned from the Kapanadze business was priceless.
Clarence does not need anyone's money. He certainly appears to have more than me.
I didn't use my money to try and back Kapanadze. That was done by my financial supporter.
If Clarence has stumbled on something new then we all benefit.
If not, at least he had the guts to go public with his experiments and all who followed his experiments
have learnt a lot.
ramset
Recently on one of the other forums or Blogs there was a fellow that shredded an OU claim as BS,
quite eloquently I might add, another Gentlemen came back a few weeks later and
made an equally eloquent post which highlighted the fact that when we do find the unusual
it will probably be a very unorthodox method which is used, Way outta the box...
I applaud Clarence and his investigation here, I also understand the Tenacious Tinman and others who have spent  thousands or tens of thousands in time and money for the benefit of others,
and how as time goes by these things can be a sore spot for them [the open source replicators].
These replicators have come to heavily rely on a measurement protocol to expedite this process
thereby saving the community as a whole.. fortunes in wasted time and money.
@ EnjoyKin
to be clear we do have very trusted and respected members that are in neighboring states
who could assist in proper measurements .
respectfully
Chet
Thanks Grandma
