Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
nelsonrochaa
Quote from: memoryman on April 04, 2015, 09:20:43 PM
"Electricity is not energy" Really? Since when? One of the units of energy (Joule) is equivalent to one Watt.second
For example, electricity can be converted TO and FROM: heat, light, sound.
Hi Memoryman,
I suggest that you think with more time about power and energy because is very important understand .
It is not that difficult to distinguish between Energy and power but can do some confusion if is not clearly understood.
While energy is the ability to do work, Power is its measurement, which calculates the time by which the energy has been used.
Power is the capacity of energy, which is being used. In more simple terms, power is defined as the rate of doing work. Power finds it use in mechanical applications, heat applications, electrical applications and several other areas.
Another difference is that energy can be stored whereas power cannot be stored.Energy changes form but power doesn't change form.
Thanks
nelsonrochaa
Quote from: tinman on April 05, 2015, 01:07:43 AM
Void
The clamp meter reads current by the strength of the magnetic field around the wire. If your clamp meter is to close to the transformer,then it may be reading the magnetic field around that transformer as well,which would be extreemly strong with your shorted 3 turn coil. Even then,1000 amps should fry that wire in no time flat. If we look at an arc welder,we can melt 2.5mm steel rods with only 60 amps,so something is amiss with your clamp meter.
Yes is true what tinman say , the amp meter will do wrong measures because the nature of the high magnetic field, i see myself this in tests that i do.
We don't need to have 1000amp in secondary loop  is a nonsense. because the "amps measured" will don't be the output power! I say that to much times.
The loop secondary is only to maintain  the core material saturated,  is not need to waste the power in heat, because with high amps will heat all coil system, make nothing then more consume ! I suggest to people that like to learn that read this pdf
and i have sure that will be helpful to people.
thanks
http://web.ornl.gov/adm/partnerships/events/power_electronics/presentations/T2-C-Power_Flow_Control.pdf
Clarence
Quote from: Void on April 05, 2015, 12:41:06 AM
Hi wistiti. No, greater than 920 Amps measured on the 3 turn secondary seems very high to me.
Why the current is measuring so high on the 3 turn secondary, I don't know.
I also don't know what the winding turns count is on the primary winding, for turns ratio calculation purposes.
The other question is exactly how are B&L intending the secondary on the single transformer arrangement to
actually be wound? Anyone have any idea or details on that?
All the best...
HELLO VOID & ALL,
Since at present it seems that NONE OF YOU have ever YET comprehended what is happening or what to do about it or HOW TO ACHIEVE IT!!!!!!!!!! I am going to tell you for one last time what YOUR
SELF CREATED PROBLEMS ARE!!!!!!!  I presented this information WAY BACK AT THE BEGINNING!!!!!! but it just BLEW RIGHT OVER YOUR HARD SKULLS!!!!!!  This time you PAY ATTENTION or I'm
done with you! I have tried to freely share with ALL of you but you have begun to annoy me to no end with your D>>> unwillingness to just pay attention! I DO NOT KNOW EVERYTHING IN THE WORLD AND DON'T CLAIM TO but the VITAL things pertaining to a build of this nature I DO KNOW!
        PAY       ATTENTION!
1. VOID your shown ATTEMPT is an attempt at another LARGER TYPE POWER MODULE which I have not shown YET! and was defeated because it was totally incorrect.
    every one needs to build the basic unit I have built      FIRST!!!!!!!!  my build is the FIRST small unit they used in their first demonstration!! when a person builds IT
    THEN the WHOLE WORLD IS JERKED OPEN to them because they will have comprehended everything that is involved in all the REST!
2.For all of you HURRY UP WANNABES I am going to tell you how to complete the basic TWO TOROID SETUP with NOTHING ELSE BUT IT!!!!! no rods , no batteries, none of the other needed items.
   if you don't want to use TWO ferrite toroids then forget it all. just go lock yourself in a small closet somewhere and stay there forever so you don't contaminate the rest of the world!
  A.the toroid MUST ONLY have a primary winding---nothing else!!!!!!!  YOU  are going to MAKE the secondary winding  of -----2 1/2 turns of # 4 AWG TINNED stranded wire.!!!!
  B.BOTH of the toroids have to be wound EXACTLY as I have shown in the previous photo i posted. go back there and sit and study it for an hour or two!  after you have MADE the winding and placed it on the
      toroid ---both the position of the toroid and the position of the secondary winding had better EXACTLY match my photo!!!!!
      set both of the completed toroids in front of you with the # 4 AWG wires pointing straight at you! now spin one of them so the # 4 wires are pointing towards each other! the two top wires CONNECT TO
      EACH OTHER!!!!!     then the two bottom #4 wires CONNECT TO EACH OTHER!!!!!!
      Join each of the primary neutrals TOGETHER!          then join each of the primary phase wires TOGETHER!
  C. now JUST FOR TEST PURPOSES ONLY connect mains power to the primary leads. there should be NO smoke! NO heat! you should be able to take a clamp meter on AC amp setting and find an amp
       reading of some where around 1.3 amps +-.
If you have success in ALL of this then you can move forward to the rest of the build!
TA! TA!
Clarence
qwekw
qwekw
