Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
ariovaldo
Quote from: vrand on October 08, 2013, 12:56:26 PM
Is your setup with 2 transformers, or 3 like Carlos?  If 2 do you plan on trying out with 3 transformers?
I tried several configurations and none of them got OU. I got some others ideas and I share with you guys.
http://www.youtube.com/watch?feature=player_embedded&v=yp57lgCXc4I
http://www.youtube.com/watch?feature=player_detailpage&v=Y3E5gLvc25o
In the first video, 2 transformers having 110 volts input in the primary ( transformer 1) and one 100 watts light bulb in the secondary ( transformer 2). The amps in the primary is 4.8A.
In the second video, the same 2 transformer but I put one of them in the top of the other. The amps drops to 2.4 A. The voltage in the secondary still the same.
This was just a test. I connect 3 transformer as my friend Carlos did and I had the same results.
By the way, using 1 transformer ans put 2 turns in the secondary in short circuit, the current goes to more than 100 Amps....
http://www.youtube.com/watch?feature=player_detailpage&v=x8Fo-rjD1ys
ariovaldo
Quote from: Dave45 on October 08, 2013, 09:03:44 AM
Maybe  :D
Good. Thinking out of the box.....
I tried that with copper. I will try using different material...Copper and iron for example....
Best Regards
totoalas
Quote from: vrand on October 08, 2013, 01:08:11 PM
Okay, thank you for the description. Please post a photo or video when you get a chance, as a picture is worth a thousand words  :)
ps check barbosa leal replication  081013  youtube   totoalas
vrand
Quote from: totoalas on October 08, 2013, 01:31:10 PM
Thank you for posting the videos.  Was there a separate ground wire connection (loops?) to your added large closed loop coil wire?  Where did the ground wire tie to?  Building ground wire system or separate ground rod outside?
ariovaldo
Good job my friend.
Thanks for sharing.
