Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Quote from: mscoffman on April 13, 2015, 10:50:51 AM
Since you asked..
Yes, I can explain how the captor transformer works in a few words.
"It is a saturable magnetic power regulator designed to tap into the utility power company
environmental ground return power circuits using a limited but independent ground rod array
design specially by Clarence."
(o)  Once working, for power companies return current, it can seamlessly work for supposed
        Telluric currents.
    We need the ability to discuss problems ahead of time (because we are smart), make a
document, and have one person perform a test as to what the group wants to see, and to distribute
the back the desired test results. This is the path to group learning and understanding of function
by principles. Simple construction techniques of post application of more "good ideas" doesn't work.
..S..MarkSCoffman
Look at my analysis, it's nothing more than a useless resistor.  You have to start dealing with electronics from a basis anchored in reality, not fantasy.
ramset
Well
I just spoke with Clarence again ,and he reiterated the unit reaches a point where it will self run the batteries and then adding more of an array brings in more energy.
I'm away helping Grammy  ATM [Motherinlaw] and will be stopping at the Core Vendor on the way home to get all the info and specs they have.
Mr. Coffman will you be replicating ?? or gathering a group so as to diminish personal investment and maximize minimal
public resources for this project ??
we can pick a builder and ship equipment to minimize expense??
Chet K
Thanks Grandma
Quote from: ramset on April 13, 2015, 05:32:47 PM
Well
Chet K
Well, I have 38 years worth of playing with, dabbling in, breadboarding, designing, debugging, selling, and manufacturing electronics and I am telling you that that statement from Clarence is not true.
ramset
Soooo
No shovel time at all ??
Even some light "worming experience"
no ??
NEXT !!
Thanks Grandma
Just to comment on the latest posting in the EF thread from the user "totoalas":
Clarence and Level,
thanks for the swift replies and flow of info..... at least we know its working....
we dont need an ou ... what we need  is how to lessen our burden of electric bills to food in the table ..... thats what matter in my country where power rates is the no 1 highest in Asia for a 3rd world country with some oil and gas and hydro / geothermal plants.......
[Translation:  Okay, I understand that the setup is not over unity, it's under unity.]
Battery voltage drop can be topped off with solar/ sg and ssg  / cap dump by Mickey's beasty sssg   lots of possibilities   rain or shine .....
now back to the drawing board..... theres a lot of DIYers out there  that can join in
[Translation:  I will plug my battery charger into the mains, then charge up my SSG main battery.  Then I will use the SSG to charge up the B&L system battery where the charging efficiency is only about 30% for a huge net loss in energy.  Or, I can spend a lot of money on a huge solar array to charge up the B&L system battery and then run that hugely inefficient system.  No matter how I do it, I am losing lots of energy and/or money.]
I remember in my test the 10 mm cable in the captor went to 90 deg C in an instant    and also the Barbosa first video showed a 90 to 120  mm captor cable
but in your case ur case  how is the heat in the captor ??? ??
[Translation:  This is confirmation that the captor is noting more than a glorified heater that wastes energy just like MileHigh stated on OU.]
