Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
ramset
Translation Translation
others have seen an un tuned Captor and its heating issues ...
who's word is that "captor" where did it come from ??
the Brazilian's ?
Thanks Grandma
Quote from: ramset on April 13, 2015, 06:05:50 PM
Soooo
No shovel time at all ??
Even some light "worming experience"
no ??
NEXT !!
And I am a graduate electrical engineer and I worked for about five years as an electrical engineer, then I went into engineering sales.  Something I don't say very often because crazy people might want to harm me.
This thing is nonsense, don't waste your time and money no matter what Clarence says.
You guys on the Energetic Forum:  Ask Clarence for hard data, pictures, and video clips.  Get him to put a Kill-a-Watt meter on the captor like I show in the diagram.  Then let's assume one of you talks privately with him and lives close enough to him for a weekend visit.  Run the thing all weekend non-stop.  Find out what battery he is using.  Determine the amount of energy in the battery.  Pick a load that will drain the battery in eight hours, and observe what happens over the course of your weekend 48-hour continuous test.  Take a sleeping bag and sleep next to the device while it runs.
Chances are Clarence would never agree to this, it would expose his fraud.
Save your time and money for your family or for a better project.
mscoffman
Quote from: mscoffman on April 13, 2015, 12:49:27 PM
Mile High,
Signal voltage levels are microvolts per meter required to drive the system. But electron currents are the *real deal*
all the electrons flowing for all voltage levels to transmit all power used in the "US" or whatever. This is a heavy duty
thing. You just need a way to bias the electron flow to flow around the toroids and then you step the current down
and the abject voltage up and you've captured it. By the way the captor multiplies real good at a DC current level
as well.
.S.MarkSCoffman
Everyone should review the radio engineering concept of the "mixer" a mixer is a multiplier, but changes the actual
numbers on the voltage and current in such a way as it multiplies physical power. One form of a mixer is a non-linear
magnetic amplifier which we are using. There is also a radio frequency form of mixer which is probably what Karpenzy is using.
So the captor transformer *is a mixer*. The carrier or IF intermediate frequency is the inverter which is physically multiplied
by the power waveform of the other signal.   I think that makes sufficient sense to stop right there.
The only other thing is the availability of the ground array to intercept the required power.
I have come up with a good analogy - the Tsunami.   The Tsunami is only about one meter deep in the open ocean
and the fish there don't even feel it. This is equivalent to large numbers of mobile electrons, but the low impedance
between ground points keeps shorting the voltage out. The ground array is as if the ocean bottom is rising right
before landfall and the Tsunami is busy converting itself to high energy "scrubbing bubbles". Most likely the array
functions becomes the difference of the conductivity of copper rods in the array vs the conductivity of the ground
to generate additional voltage rise.
I'm sure the math for this would be covered on some book on utility electronics.
To me this should be enough to justify moving to the next set of targets.
By the way this is the same method that Brazilian captor worked except it probably had a dynamic range
of 100KW!  I suspect it was *haywired* then *potted* to prevent people from easily analyzing its function.
.S.MarkSCoffman
Quote from: mscoffman on April 13, 2015, 06:45:17 PM
.S.MarkSCoffman
Then please go ahead and sketch out the various voltage, current, and power waveforms for the input and output for the captor device.  Explain the waveforms and how everything works.  Explain the math.  Explain how it integrates into the full system.
Amplifiers require a power source to work, they don't just magically "amplify."
QuoteBy the way this is the same method that Brazilian captor worked
Please cite multiple credible references that show that the Brazilian captor worked.
Pirate88179
Quote from: nelsonrochaa on April 13, 2015, 06:31:43 AM
Man you are a curious person... What is your idea with this speech so corrosive? The hunt is over do not you understand?
People asked not only for testing, but criticized a less correctly, this is what i see in this topic .
Your speech shows well what your intentions.
Note that these not contribute to appease this topic, only to flare were more nap know?
You need attention? Work for it! but not with these derogatory remarks. Maybe you need to feel involved in some kind of project like
LED flip flop circuit or something this genre. You will able to make lots of measures .... in your home and show to your friends that like this kind of game !
Flip flop flip flop
So, someone is faking a fake device and now many folks are going to waste over $2,000 each to attempt to replicate and you think that is OK but you have a problem with my post?
To me, that is derogatory, and so is your post if you just sit by and watch this happen.
Perhaps you don't have the background to know any better?  Fine, that is understandable.  But, I do know better.
This is fake and does not/can not work.
It is as simple as that.  If you do not like my saying that, I suggest that you do not read my posts.
Good day,
