Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 47 Guests are viewing this topic.
Quote from: ramset on April 23, 2015, 01:00:34 PM
Betwixxed your"" On Topic"" Fairy's nancing and prancing posts
can you Please site one example where I have ever asked you not to post.
MH
so you pee'd in Clarence's Punch bowl and feel he should just "man Up"??
whats the big deal?
Why'd he leave his own party like that???
If he does decide to come back ,can you just refrain from commenting until such time as there is something which is not self evident ??
almost every one I speak with has measured different power levels at ground points
even a few inches a part, some have found tree's and lit LEd's between them [Tinman's friend]
others have told me about there experiences spreading grounds around over areas and finding very odd things.
I truly wish to understand How Clarence has measured this claim,as do many others.
ramset
That's a technicality ...with a Please refrain request.
Not really a "No post" order...
*At the time Void had mentioned that Clarence was on a sharing exchange here
until you came into the room with your Hair on fire!![I thought you pee;d in the punch bowl
too but that was just an ugly rumor...
well... And Tinman was considering replicating But it was cost prohibitive with out
some more info to justify the claim [in his opinion]
Thanks Grandma
Quote from: skribat on April 23, 2015, 07:44:42 AM
I don't have to do better than anything .. .. .. and that isn't the way to get me to give up my free time to go searching things for you ..  either you would like to see it or you wouldn't as things are at the moment I really don't give a damn. .. so take it or leave it .. go search for it yourself.
All right, let me put it this way.
I know more, and more importantly _have demonstrated more_ about these topics than you, or the presenter in the video you linked. "Tesla's little secret"? Again, I laugh at you. 10,000 kW? Do you understand the difference between Peak Power and Average Power? Many people who post here apparently do not. I've shown devices here repeatedly using "tesla's little secret" that have Peak Power output in that range.... but I  know fully well that they are not "overunity" and I know why and how they attain those Peak Power levels. You put your faith in a rather obvious hoaxer, fine .... you really are wasting your "free time" and you'd be better off doing something productive on your own, or educating yourself about the _facts_ of Telsa's actual work. If you want to know some real information about real modern research into Tesla's work, find and read the work of the Corum brothers.... if you are able to understand it. Or continue with your delusion that Kapanadze has something worth while.... I don't give a damn, take it or leave it.
But when you post nonsense, I'll call you on it every time I see it.
Grumage
Quote from: MileHigh on April 23, 2015, 12:04:43 PM
Grum:
Thank you very much for doing the tests.  That shows a very high resistance.  I don't know much about ground rods but I will make a few guesses.  I think I read somewhere that a standard grounding rod is about eight feet long.  I am going to assume that in most areas that are not in very dry climates it allows the grounding rod to make it down to the water table.  Perhaps not the water table but something like a region where the soil is permanently moist and just a few feet above the actual water table.  One assumes that then the resistance between two grounding rods one meter apart would be quite low.
I am absolutely NOT asking you to do that, I am more than content to guess at this point in time.  I can always do the research myself if needed.
Dear MileHigh.
You're welcome.
Here in the UK the  " Bog standard " earth rod is 4' long  ( 1.3 M ).  We are very lucky to have a comprehensive earth connection provided by the various supply companies. So earth rods, for the most part are used as back up, " Belt and Braces " so to speak.
I remember when the Pump storage scheme being built near Llanberis N Wales the CEGB had to install a massive mat under the bottom lake to get sufficient " Ground " due to the areas lack of soil depth. It still did not prevent a massive disruption to local telecommunications when an Earthing test was carried out !!
Cheers Grum.
mscoffman
Anyone wanting to take power line data on their captor and ground rod array should get something like this..
http://powertronics.com/products/probe-100-plus-rs232-120v-ac-power-line-monitor#
It hooks to a portable or desktop computer USB port and records line conditions voltage etc. This would be plugged in
parallel to the captor's battery charger. A load of 100Watts on the captor would be indicated.
A days worth of data is a days worth. Up to a year could be reasonable coverage of data amount though one would
want a small UPS for the computer to step overpower outages.
..S..MarkSCoffman
