Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
skribat
Dear Cangas 162 . I'm pleased to see that you also noticed that his attention span appears to be failing .. he is still remembering what he read 20 years ago instead of properly evaluating things put before him. he has become abusive and a lost cause, a complete waste of time and now people don't wish to communicate with him.  Most of the questions he asks have been deal with several times, the information is out there and he is too lazy to properly read the posts. sk
CANGAS
Quote from: TinselKoala on April 21, 2015, 10:51:29 PM
So Clarence has 60 ground rods pushed... not BEATEN, but pushed... into the ground in his yard?  I just have one question:
Who mows his lawns?
(That map is interesting. Do you want to be where the field is strong? Then the Upper Peninsula of Michigan looks like where you want to be. I've heard the mosquitoes there are the size of small sparrows. And I do believe it gets rather cold in the winter. But the ice fishing is supposed to be good.)
Well, Tink, you seem to have a common problem with the other professional naysayers around here: you don't waste your valuable time to actually read the news. To your obvious total lack of knowing, commonly said, in your ignorance, his lawn mowing is no problem. Clarence ground rods and their wiring are all under the surface of the ground, after installation, according to rules of the land-owner, as plainly written early in this Thread, as any fool could have clearly seen. If literate.  :) And if having the common human courtesy of actually reading the Thread before blustering into it like a drunk African bull elephant.
CANGAS 165
CANGAS
CANGAS ONE-SIXTY:  You are one firey aggressive animal of a man.
Skribat:  You are the sidekick of wonder.
Both of you:  Have you noticed that Clarence's stock has been sinking fast on EF?  If you want to be ahead of the game you should short-sell him.  Explain to us how this contraption works?  How does it actually work?  Please annotate a schematic and post some timing diagrams.  There are synchronous AC power supplies in the GROUND?   Something like, "There's juice in them thar hills?"
If you both believe in this quackery, then why don't both of you GO AHEAD AND BUILD IT?
You both are probably on EF also?   Why don't you ask Clarence where you put your multimeter probes on his schematic to verify the measurements he talks about?  Look at post #1741 to see Clarence's instructions.
You want more information from another high technology free energy company that also leverages battery and inverter technology?  They may be able to help you with your builds:
www.magnacoaster.com
Some comments from Level on EF worth repeating here:
Hello citfta. I had already pointed out to Clarence in this thread that the Barbosa and Leal patent does not show the neutral being grounded with another separate ground connection like that. Clarence replied that he was intentionally making it a SWER (single wire earth return) setup, as that is the only way he could get his setup to 'work'. It is obvious that Clarence does not have a technical background, and therefore what he may think is 'working' appears to be just the battery powering the system through the inverter. His battery starts to run down after running a load for a little while, and then he has to recharge the battery by plugging the battery charger into the mains. I have been holding off completely ruling out something out of the ordinary going on in Clarence's setup on the off chance that the 'captor loop' part might actually be adding something to the performance, but with Clarence pretty much refusing to do any meaningful analysis of how his setup is performing, we just can't say for certain.
We could have easily sorted this all out very quickly if Clarence had been open to doing some very basic tests regarding how his setup performs under a few different conditions, but it appears that this is something that Clarence was afraid of finding out. It seems he may have wanted to just blindly believe that his setup is over unity, and therefore wanted nothing to do with any testing that might show otherwise. The only other explanation I can think of for Clarence's behavior in this regard is that Clarence knew his setup was not working, but he believed he might be close but thought that the problem was with the earth ground not being suitable in his area. By claiming that his setup was 'working'  and encouraging people to replicate, he may have been hoping that someone might get it working and show to Clarence that the problem with his own setup was with the earth ground in his area. However, I don't think it is likely that is what the problem is with Clarence's setup. I think that if Barbosa and Leal's devices really can self run, then there may be one or more things that they have hidden or misdirected in their patent documents that replicators are still missing. There is of course also the possibility that their devices just don't work at all, but I am still not jumping to any conclusions myself about that yet.
Don't be surprised if Clarence is on his last legs, on his way out.  In this day and age you can disappear with a single click of the mouse.
