Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 101 Guests are viewing this topic.
earthenergy
BTW meters prove nothing. Put an amp meter near a plasma ball and you'll get tens of amps. It's easy to fool clamp meters
with a bit of circuitry.
A.King,  I am wondering now if they are clamping the meter on the lead that is not going to ground... that would explain the .1 amp reading
Also now wondering now if the devices were taken because the utility figured out they were loading to ground.... could be the case!!!!!!!
MenofFather
Metters show corect, but then meashured Leal curent 0.1 amp, then is not good, that he meashure only one cable going from socket with clamp metter, he must meashure ant other cable, maybe if he meashure and oher, then we see 25 amps?
havuhung
Hi a.king21
If simply conclude that (Barbosa and Leal device) does not work, will not convince everyone!
With the ingenious tricks that will make anyone look and will talk, that equipment is working!!!  Example : Device effectively collect energy from the ground to receive it : ( But please you read : I just gave an example to look wide and I do not take any responsibility if someone that this self-realization and self risk you take ) . You have to find somewhere to the ground wire from power transmission towers high voltage (>22,000 voltage), in a foggy weather conditions , rain , wet ground ! Leakage power safety devices on the transmission line will connect the ground wire to a voltage ( pretty high ) . And from a metal bar deep into the ground near the tower grounding wire , connect the ground wire from the metal bar to your device will get power! ;D
Why, it was working before your eyes???
FatBird
It looks like all of his units have a LOOP out in front for checking current.
earthenergy
Quote from: MenofFather on January 01, 2014, 01:12:12 PM
That is correct, the meter clamp should be put on both leads, one lead first, and then the other, just measuring one side is not proof. The current could be going through the other side, through the load, and then to ground.
It seems unusual that they have not been 'called on that' prior to making the video and would already know to demonstrate current flow in both leads, not just one.  It would also seem that, at one point or another, they would have seen the current flowing through the other lead and would then realize they were getting their power from the utility and not the ground.
You would also think they would be called out by someone at the trade show and made to put the clamp on both leads.....
The responsibility is certainly on them to produce a better video with a first class demonstration of loading. Only one, 1000 watt bulb is necessary, and it should be up on the table where all wires can be seen and identified.
To their credit however, they do clamp the meter on both sides of the input of the  large device and show the load going into the large device as identical on both leads. So if the smaller box is wired in the same manner, it would also show identical loads on both input leads. So the jury is still out.
