Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 101 Guests are viewing this topic.
MenofFather
Quote from: a.king21 on January 01, 2014, 08:25:46 PM
How can a trafo work on DC?
This I also not understand. But if you make trafo on DC, you get electromagnet. In secondary windings is few turns of wery tick wire, to get wery much amps, in AC wery mych amps maybe create wery strong magnetic field, who mayve atracts electrons from ground, but in DC I dont know how explain, need jus try, that will be like in my schematic. But using DC need much more windings on primary and with tiner wire, to not get chort circuit.
MenofFather
Quote from: FatBird on January 02, 2014, 07:37:23 PM
Great Post Romerouk,
Yeah, I too am wondering if it has an AIR CORE because just the EMPTY METAL BOX should weigh 3 or 4 pounds.
Looking at the Spec Sheet below (posted on their site) their SMALLEST UNIT weighs 1.5 KG.
http://energiauniversal.eco.br/
In air core you must have hight frenquency. And in patent is metal core drawed, who in perspective, but in 2D patents, no core. But you need wery much wire, to run on 50 herc on air core. Maybe 1000 meters wire.
MenofFather
Quote from: earthenergy on January 02, 2014, 10:38:16 PM
Here is an exciting overunity transformer, perhaps it is on another thread, but thought I would post here regardless. It is called a joule ringer. No amp meters needed to verify the efficiency of this device.
Not sure how to embed here on OU.....
https://www.youtube.com/watch?v=homZvbKZHlU
This is a newer version https://www.youtube.com/watch?v=DcFHZMhnV2g
Here is the latest, very amazing....
https://www.youtube.com/watch?v=M3YWB-noPNo
Joule ringer is not overunity. It have eficienty about 80-93 precents. If it overunity, why nobody can not make selfrunning?
havuhung
Hi All,
How to know the direction of the electric current is measured in ampere clamp from a piece of wire?  Is to determine the current power line from the device is being run into the ground, either from the ground up equipment?...
MenofFather
Quote from: havuhung on January 03, 2014, 02:37:57 PM
Hi All,
Direction you can not know. I can ask you or water cold makes water warm colder, or water warm makes water cold warmer?
