Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 38 Guests are viewing this topic.
havuhung
Quote from: ariovaldo on March 19, 2014, 01:35:27 PM
I agree with you...Why somebody will spend a lot of money with a system that looks like a scam?
I tested the equipment and it did work in my place, probably because the grounding system was not so good, but the same equipment was tested in a good grounding system before and didn't run either.
Cheers
Ariovaldo
Hi All,
Things on my mind and I have also found an answer is: There are some people they like and in any way that they tricked you, if successful with these actions, they are delighted and says, 'I've tricked it really stupid when guys listen to us!
Well, they always cheat people and are proud of what they've done! :(
Havuhung
Collapsingfield
http://pesn.com/2014/01/30/9602431_PESN-rep_witnesses_Evolucoes-Energia-Captor_off-grid-overunity/:
"They hooked the Captor to a 90 Amp-hour battery with a DC/AC inverter that drew 21 A at 12 Volts DC that, in turn, fed the Captor with 252 W at 230 V. They then hooked a 1,000 W lamp and a 600 W heater with a total load of 1,610 W. That comes to a ratio of nearly 6.4 times the power drawn from the inverter -- not as good as what they observed at a higher power level from the grid, but definitely an overunity effect of a very significant level."[/size]
MenofFather
Here http://pesn.com/2014/01/30/9602431_PESN-rep_witnesses_Evolucoes-Energia-Captor_off-grid-overunity/TESTE_BATERIA.pdf
Use in to 2000 W iverter [size=78%]11,72 VCC[/size]
55,4 A = 649 W (0,649 KW)
out 237 VCA x 815 A = 193.115 W (193 KW)
Energy amplification, more than 200 times.
If I good understand foreign language. :D ;D
Edit: But seems they meshure closed loop but not amps on load.  :o  seems they use tick iron pipe as resistance, so meashurements may be not wery correct.[/size]
ariovaldo
Quote from: MenofFather on March 20, 2014, 09:20:25 AM
That isn't true. The amps they are getting is in the secondary. If take a look in the movie that I made, I got 80 amps in the secondary, so 80 X 110 volts will be 8.8 kw and that isn't true...
totoalas
its like a welding machine as shown by Thomas kim video
my 6mm pvc sheath  melt only after 5 minutes so maybe there is still a use for this in heating application
