Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 27 Guests are viewing this topic.
zcsaba77
Quote from: Acca on July 03, 2014, 05:44:24 PM
Thanks to NelsonRochaa on overunity thread for  "Barbosa"
Barbosa power generator video clip(s) on Youtube below..Duplicators !!!
Acca...
https://www.youtube.com/watch?v=wbNvUZT4NC4
https://www.youtube.com/watch?v=KAtRv6PneNs
Hi Acca
This device is truthfully?
regards zcsaba77
penno64
What would be most interesting to know is -
what does nelson's electricity meter (power provider meter) do/show when he connects the motor and soldering
iron to his device ?
Penno
nelsonrochaa
Hi Penny  is pertinent to your inquiry. My counter is digital it works with pulses. When i have a chance i try to verify analog but I could see that the numbers of pulses in the counter does not increase when the circuit is connected to load.
In my opinion the circuit is not returning energy to the electrical power network but to consume reactive power that the engine generates during operation called reactive power displacement.
This phenomenon is caused by the harmonics created by the circuit and.
Any device that bind to the circuit always will have a power factor of 1.
  You can do a test with an inductive or capacitive and resistive load.
The three have different values ​​of power factor. 1 is the most efficient and usuis pertinent to your inquiry. My counter is digital it works with pulses. When you have a chance try to verify analog but I could see that the numbers of pulses in the counter does not increase when the circuit is connected to load.
In my opinion the circuit is not returning the electrical power network but to consume reactive power that the engine generates during operation called reactive power displacement.
This phenomenon is caused by the harmonics created by the circuit.
The three have different values ​​of power factor. 1 is the most efficient and usually resistive load is usually 0.98.
But inductive loads in the case is different. Forehead and takes your findings.
Besides being the power factor of the circuit always mean that one is not using reactive power from power network.
thanks and good tests.
wayne49s
"https://www.youtube.com/watch?v=wbNvUZT4NC4"
There's no over unity here. The phase line has 2.4A, which is returning to grid source through the ground back to the network ground, bypassing the neutral line. In order for over unity, the phase current after the secondary loop should be greater than the phase current before if the secondary loop is contributing to the current flow to the load. I don't see the current loop doing anything.
nelsonrochaa
Hello wayne rightly so, in the video you describe
the phase of the electric network is being conducted by grounding doubt that anyone has doubts. That's not the idea.
The neutral is in use as the grounding and your protection in my circuit.
you can verify that consumption increases  the loads used by varying their behavior depending on the type of cargo ex (inductive, capacitive or resistive). Thus the effect is different from that which you speak.
thanks
