Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 27 Guests are viewing this topic.
havuhung
Quote from: wayne49s on July 04, 2014, 05:10:23 PM
"https://www.youtube.com/watch?v=wbNvUZT4NC4"
There's no over unity here. The phase line has 2.4A, which is returning to grid source through the ground back to the network ground, bypassing the neutral line. In order for over unity, the phase current after the secondary loop should be greater than the phase current before if the secondary loop is contributing to the current flow to the load. I don't see the current loop doing anything.
Hi wayne49s,
The loop device is only to fool the observer! . . This device has no power to effect capture from the ground, in fact it is a device used to deceive kWh meters, use ground bar to replace the neutral wire of the power supply area. . . You can be electric shock by touching electrical appliances and device connected to the safety ground with metal casing!!!    :(
nelsonrochaa
Man you are so smart ! I don't have copper ground bar in my home i live 9º floor !  And sure a will show the circuit working and i will measure in other socket ground and neutral to you see the danger that you talk ...lol
Or if you like a can put my hand in the ground.
Not talk about the things that you can understand .If you want to help give suggestions to improve the tests not only talking.
bye
Farmhand
Nelson, can you post a schematic drawing of the arrangement you have ? I looked but I couldn't find one posted by you.
If I missed it I apologize.  :-[
We need a drawing of the circuit to be able to follow what you're actually doing.
wayne49s
Hi Nelson,
I didn't comment on your post because, like Farmhand, I am not totally clear on your circuit details without a schematic.  I notice in your earlier video. that you have something like a capacitor that is connected even with the AC test that you did. Also in the video, it looks like you are using the power cable to form the current loop. You don't seem to have a separate ground beyond the neutral which the power company presumably connects to ground. [size=78%]So a schematic would be very useful for readers of your posts.[/size]
In your conclusion, you are claiming ou and somehow the circuit converts reactive power to real power? That itself would be useful from an ou point of view as it is readily possible to generate much more apparent power VAR then watts.
Any clarification would be appreciated.
/Wayne
viejo loco
español
loe traducido en google, perdon no se ingles, buenas llebo mucho tiempo sigiendo este tema, pero siempre pasa lo mismo, cuando algien consige algo o cree consegirlo, luego desaparece o borra todo, paraque bale el esfuerzo de las personas si luego no se comparte, si asin queremos tener un mundo mejoreso es imposible , primero tenemos que aprender a ser nosotros mejores y para eso hay que compartir, de que bale decir que conoces el secreto de algo , si luego no lo compartes, como se sabe si es cierto lo que dices, por ese motibo rogaria que, pusiera esquemas, :-X
ingles
loe translated in google, sorry no English, good llebo long you sigiendo this topic, but always the same, when algien consige something or create consegirlo, then disappears or delete all Paraque bale effort people then if not shared if asin you want to have a mejoreso world is impossible, we must first learn to be our best and for that we share, that bale say that you know the secret of something, and then not share it, as you know if it is true what you say, for that would beg motibo that put schemes :-X
portuges
loe traduzido no google, desculpe não Inglês, boa llebo tempo você sigiendo este tema, mas sempre o mesmo, quando algien algo consige ou criar consegirlo, em seguida, desaparece ou excluir todos paraque esforço fardo pessoas, então se não for compartilhado se asin você quer ter um mundo mejoreso é impossível, devemos primeiro aprender a ser o nosso melhor e para que partilhamos, que bale dizer que você sabe o segredo de alguma coisa, e depois não compartilhá-lo, como você sabe se é verdade o que você diz, por que iria implorar motibo que colocar esquemas :-X
