44 Times More Power Output than Input
Started by e2matrix, September 04, 2013, 01:10:28 PM
e2matrix
    I don't believe this device has been picked up here yet on Overunity so I'm looking for discussion on it.   It seems from my quick skim over the material that it has been done in a very scientific way with a lot of controls, data and calculations along with extensive discussion of theory.   Video here:  http://www.youtube.com/watch?v=6CleoildQFM
And nice write up in PDF here:  http://www.worldsci.org/pdf/abstracts/abstracts_6483.pdf
It doesn't even look that hard to build.   This was 4400% OU with just 2 motors (cheap inefficient Radio Shack motors) but can be run with more motors easily increasing the output to input percentage a lot more.
tak22
Thank you for this info. At first glance it looks worth consideration and I just happen to have a supply of new DC motors sitting around waiting for a purpose.  :)
I wonder if the effect only works with PMs? I can see using EMs or other magnetic field generators that have a higher field density.
tak
gotoluc
Thanks for starting the topic
Does it say anywhere how the round magnets are polarized? ... I would guess each half of the magnet circle is a pole?
I don't know why the spinning magnet poles would not cause a generator effect back to the coil?
Luc
tak22
3/4" NeFeB Ring Magnet x 1/4" Thick x 1/4" ID, magnetized through thickness (direction of rod)
gotoluc
Quote from: tak22 on September 04, 2013, 03:54:35 PM
Thanks tak22
The magnetization through the thickness is surprising. With the poles in that direction it should not cause a generator effect in the coil.
Surprising the magnets will spin that way. I'll have to try this one.
Thanks for the info
Luc
