Thanks to ALL for your help!!
Roy Davis and Rawls Magnetism Discoveries
Started by hanon, September 07, 2013, 08:00:06 PM
hanon
Hi all,
In the link below you can download the book by Albert Roy Davis and Walter Rawls "Magnetism and It Effects on the Living System".
http://www.mediafire.com/view/du8271s882xf9kd/Magnetism_and_Its_Effects_on_the_Living_System_by_Albert_Roy_Davis_and_Walter_Rawls.pdf
As you could verify their findings are in agreement with those of Howard Johnson and also Leedskalnin. Roy Davis and Rawls also state that there are two types of magnetism  (one from the north pole and one from the south pole, one of them good for the health and the other bad for the health).
Also they state that the intrinsical nature of magnetism create a vortex with different direction of rotation in each pole. The magnetic flux lines convenge in the center of the magnet creating a neutral zone ( Bloch Wall )
As you can see their findings are in complete agreement with those for other non conventional magnetism researchers. Mainstream science should revise this findings.
I hope you could find useful this post.
PS. Book by Howard Johnson "The Secret World of Magnets" http://www.freeinfosociety.com/media/pdf/3935.pdf
The figure "Bloch Wall Illustrated in a Magnet" includes the description "Point of Zero Magnetism known as the the Bloch Wall."
Okay, so a magnet is a bar of iron that is permanently magnetized.  So what happens if you cut a bar magnet in two?  Does the Bloch wall of zero magnetism in the original permanently magnetized magnet all of a sudden get magnetized?  Do the new smaller permanent magnets have new Bloch walls of zero magnetism that magically appear in areas that formerly were magnetized?
So does that mean every time you cut a permanent magnet in two you get one Bloch wall that magically disappears and two new Bloch walls that magically appear?   All this inside permanent magnet material?
This is what it looks like inside a permanent magnet.  The boring conventional explanation is true and reigns supreme.
When you slice a magnet in two not much happens.  No magic magnetization and demagnetization events take place inside the permanent magnet material.  Life can be so simple sometimes.
hanon
Hi MileHigh,  I undestrand you because it is not easy to accept such a big change
The problem with mainstream science is that he/she does not admit any experimental test against its foundations. In the book by Howard Johnson is descrikbed the experimental method used to measure those fields.
It is simple: just a Hall detector and any magnet that you choose. Please just read quikly his book and you would find some interesting subjects for any curious mind. We donĀ“t have to settle principles which seem graved on stone.
http://www.youtube.com/watch?v=_xq9VVGYoSU
http://www.youtube.com/watch?v=m_JE7tFFaPo
www.youtube.com/watch?v=wR7c4iXum-A
http://www.youtube.com/watch?v=3grPo81fBrA
http://www.youtube.com/watch?v=wMoYEQFhQoc
I am looking for some other videos showing those effects. If anyone have some videos or links please post them to enrich this forum.  Thanks for your collaboration
Hanon:
I looked all all of your clips and they prove nothing.  They mostly consist of people that don't know what they are doing and don't understand what they are observing and then arriving at wrong conclusions.  That's a foolish and potentially dangerous state of affairs.
I raised the issue of the magic disappearing and appearing Bloch walls when you cut a magnet into two halves and you ignored it. Chances are that just about any proponent of this false notion that a Bloch wall exists in the center of a magnet will ignore it also.
There is no evidence that a Bloch wall exists in the center of a magnet and tons of evidence that one doesn't.  All that you have to do is open your mind and open your eyes and start doing some critical thinking.  Don't let yourself get deluded just because you want to believe that "alternative is cool."
