Self Running Motor Generator - for sale in 3 weeks
Started by e2matrix, September 30, 2013, 01:27:23 PM
totoalas
Jasondaz2009  has shown  in YT his recent Meralco bill wayback in May2013 and was also featured in Peswiki
totoalas :)
e2matrix
Quote from: totoalas on September 30, 2013, 05:43:39 PM
totoalas :)
Yes I saw that one also and while it looks good it doesn't seem to involve a flywheel.   It does appear he will be selling it in his country and possibly plans too.   If enough of these type machines come out at the same time I think it will be hard to stop the revolution that may come about.
tinu
 Hi e2matrix and all,
Quote from: e2matrix on September 30, 2013, 01:27:23 PM
However I'm sure the biggest question is does this really work?
Lights flickers several times during start up – that's normal, of course. But what's abnormal is they flicker when the "self-powering switch" it turned on (at 01:08). Go figure...
Again, part of the wiring is done through the metal chassis?! And, like tak22 noticed above, the contraption is conveniently placed on wooden boards and, moreover, quite close to the power outlet despite the fact that power cord is several meters long. Also, I'm pretty sure that the wooden board extending under that working bench (and under that wooden box too!) was pure accidentally placed there and nothing is hidden underneath...
Not to mention that if I've had a device like that, it is absolutely certain I would've started it mechanically. Wouldn't you?!
On the other hand, if you can agree with the inventor for a close inspection (with measurements and everything), I can do it for you  assuming he's not too far from my location. But please get the agreement; from what I've seen already, imho it's not worthy to spend the time for even a phone call. Contact data is on their site. Oh, almost forgot to mention that their site says that: "autonomous systems will be manufactured within 3 months after signing the contract".  That's 3 months not 3 weeks. <Autonomous system>  in Romanian language is <sistem autonom> and <months> is <luni>.
Best regards,
Tinu
tinman
Quote from: ariovaldo on September 30, 2013, 01:55:43 PM
It looks like a normal motor and normal generator.
There is another video that I saw sometimes ago.....
http://www.youtube.com/watch?feature=player_detailpage&v=98aiISB2DNw
What do you think?
The configurations looks like approximately the same.
This was done by a fellow australian years ago(Chas Cambell).
25 globes at 100 watts each=2500 watts,but watt meter says 2100 watts-400 watts missing some where?.
tinman
Guy's
Please tell me your not falling for this one?.
As tinu said-one short piece of wood under one set of legs,and a long piece that go's under a box,under the table.Motor power cable inside box section,so as cant be seen where it is running-through to the switch and down the leg,then under the board to a power supply i suspect.
Take note of how much energy(power) was required to build the flywheel speed up to running speed. Once up to speed,you now have one large energy reserve.
The angle grinder may be rated at 2000 watt's,but will not draw that much when up and running,unless fully loaded down. Only a short burst of high startup current would have been required to get the grinder up to speed. Using the grinder as he was,would not use any where near it's rated power capacity.Same go's for the table saw-a quick burst of startup current(dampend by the flywheel),then a small piece of wood cut.
Then when he used the welder,you could hear the flywheel winding down quickly-this is why he only did a few quick runs with the welder.
This is clearly a fake-scam,and the warranty would only cover parts-not a Guarantee of a self runner.
Every part in that setup runs at a loss,as far as mechanical to electrical go's.
Electric motor=loss,due to heat disipation and ohmic losses
Bearing's=loss,due to heat and friction
Belts=loss,due to heat and friction
Generator=loss,due to heat and ohmic losses
Flywheel=loss-due to air friction.A flywheel will only ever give back what you put into it-nothing more.
Your first look should be to find where gains might be made. If you only come up with losses(as listed above)and no gains-then you have your answer.
