Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
@Milehigh,
Do you own any bar magnets? I purchased the full range of neodydmium spheres, tubes, and disk magnets
from the largest to the smallest and own hundreds of bar magnets. My theories followed my test results not the other way around. Every magnet has two poles and a neutral zone between the fields of opposite spin wherein there is no attraction force in either direction.
Conradelektro has proven something of value; Weak low grade magnets won't produce the "Cook effect".
The only experimenters who can contribute worthwhile results are the ones who can afford to buy powerful high grade magnets to experiment with. Why can't you afford to buy magnets of this kind to help?
conradelektro
Quote from: synchro1 on January 06, 2014, 09:10:59 AM
@synchro1: why do you always twist the facts? Attached find the specification of the magnets I used to build both versions of the "synchro coil", they are "high grade" Neodymium NdFeB / N45 (6 stuck together to form a tube).
Greetings, Conrad
Synchro1:
QuoteWhy can't you afford to buy magnets of this kind to help?
WHAT?  Did I ever say that I can't afford to buy magnets?  You have to stop putting words in people's mouths.
QuoteMy theories followed my test results not the other way around. Every magnet has two poles and a neutral zone between the fields of opposite spin wherein there is no attraction force in either direction.
Your test results are correct but your theories are wrong.  "I see no attraction therefore there must be a Bloch wall" is wrong.  Please do the research online or get some books on electricity and magnetism.
synchro1
Quote from: conradelektro on January 06, 2014, 09:37:29 AM
Greetings, Conrad
Don't you think accusing me of "Always twisting facts" is putting a bit too much on it?
Get serious! Your magnets are a full five times smaller then the ones I used in length and half the width. That's a factor of at least 10 times less powerful. You need to link twenty of those magnets together to equal the strength. Cook's ferrite cores were six feet long. Try and couple as many large diametric magnets as you have together, place a wrap of dielectric tape around them, give them a light coil wrap and retest for the spontaneous charge!
The magnet core coil won't work as a flux field generator if it fails to generate the spontaneous charge from the "A" vector potential. It doesn't matter how large it is! You can get this to work if you try hard enough.
Magluvin
Quote from: synchro1 on January 06, 2014, 11:51:36 AM
Why the great push to have Conrad do tests that you say you have done yourself? Why cant you show 'your' results first?  Something is weird here. ???
Are you afraid to show the results??  So you want someone else to show them so they can take all the risks of showing, if it works at all?  Thats the only reason I can come up with. ???
Mags
