Stivep1: Tesla Rehash (Akula device)
Started by jbignes5, October 02, 2013, 10:19:57 PM
d3x0r
Some translated schematics; had to guess a little; for example what is TT?   Volume? Vols? Comarade?
Most of the component values are roman alphabet already;  going to work on the coil specific; lots of text there.
e2matrix
Quote from: d3x0r on October 26, 2013, 02:37:26 PM
TT = Tesla Test ?
TTL - commonly transistor transistor logic
but probably Tesla Test or Tariel Test ?   ;)
Thanks for working on some translation of these.
d3x0r
TT is current transformer (ok last edit)
чистоты указаны по показанием приборов
и имеют ориентировочное значения их соотношения
чистота ТТ передю Равна чистоте ямр выходного бифа ТТ приемного
purity are for indication devices
and have an approximate value of their relationship
purity TT Before Equal to clean NMR output Beef TT receiver
количество витков вв указано
согласно первичной обмотки
и в процессе настройки менялось
точное количесто не известно
number of turns of centuries indicated
according to the primary winding
and in the process changed the settings
the exact amount is not known
ПАПУЧИВШЫЙСЯ РЕЗУЛЬТАТ Я ПАЛАГАЮ И ЕСТЬ РЕЗОНАНС В РЕЗОНАНСЕ[/size]
РЕЗОНАНС ТОКА И НАПРИЖЕНИЯ  ПЛЮС РЕЗОНАНС ЯМР!!!
(the results I received) result I PALAGAYU(KEWL!) AND IS resonance in RESONANCE
RESONANCE OF CURRENT AND VOLTAGE PLUS Resonance NMR
все намоточные расчеты проведены на основание лабораторных испытаний всех проводников.
испытания проводились на токовые и частотные характеристики с формированием спектра
дия выявления всех  работавших    проводне примесей и пониманя  реальной картины
работы ЯМР проводника из которова изготовлена экспериментальная модель
All calculations were reeling from laboratory tests of all conductors.
tests were conducted on the current and the frequency characteristics of the formation of the spectrum
Diya(?) identify all worked wired impurities and understanding of the real situation
NMR of the conductor is made of Korotova(?) experimental model
(lower text; left as original )
испытания проводились в лаборатории при институте по изучению ядерной знергетики
по адрису казахстан г. курчатов "парк ядерных технологий"
tests were conducted in the laboratory of the Institute for the Study of Nuclear znergetiki
by Adris Kazakhstan Kurchatov "Park of nuclear technologies"
Блок согласования и формирование собираеца согласно получившимся
параметрам резонанса тока и напряжения приемного ТТ
С учетам моментов времени в процессе работы которых создается
Matching unit and formation sobiraetsa agree to receive
Resonance parameters of voltage and current receiver current transformers
Taking into account the time during which the work is created
(translation mostly google translate with some external searches to discover context of other words)
arksie
Witaj Wesley
Jeżeli dobrze zrozumiałem, wyposażenie próżniowe jest w Twoim posiadaniu. Możesz więc przeprowadzić doświadczenia, których ja nie przeprowadzę z powodu braku odpowiedniego sprzętu.
Więc do rzeczy, chodzi mianowicie o "oświetlenie" cewki nawiniętej bifilarnie (tej z patentu Tesli 512,340) katodą w kształcie reflektora parabolicznego również z patentu Tesli 685,957. Wszystko, czyli katoda i cewka mają znajdować się oczywiście w komorze pod zmniejszonym ciśnieniem.
Moim zdaniem właśnie tego typu lampy zasilały elektryczne auto Tesli.
Pozdrawiam
Arek
