Stivep1: Tesla Rehash (Akula device)
Started by jbignes5, October 02, 2013, 10:19:57 PM
d3x0r
Thank you again, kind sir :)   (Did you mean to make the second one private?)  Given the disclaimer of potential desync it's not so bad... I got the idea of what the circuit is meant to do on that side; but that's only 2/3 of it :)  I know I'm impatient...
signal tracking with a time skew... with a lowband and high band limiter....
the  drive should probably be at the opposite side from where you take a load? or both?  I think a royer oscillator would track similarly... more of an analog solution
but I'm finding local parts that can build this...
NTE74HC14
http://www.frys.com/product/1003633
NTE4046b
http://www.radioshack.com/product/index.jsp?productId=13076432
(Not this one; it's just an output driver module... 10-20V logic input)
http://www.irf.com/product-info/datasheets/data/ir2111.pdf
the output module is really rather complex... uses 12V to drive a coil to drive mosfets that drive 24-220V rectified power input across the real inductor...
This probably lays out on a board pretty well; need better package for power drive :)
(sorry if I'm interrupting and edit in progress)
d3x0r
Tracked down some more information; from what I gather There is an important concept from
(Tesla 7 N. TBSLA. ELECTRICAL TRANSFORMER OR INDUCTION DEVICE. )
delayed induction by iron layers between primary and secondary; Assuming a direct induction to get the current rather than a delayed effect from collapse of a field ....
Akula's thread, locked from public comment, which is probably for the best :)
Was reading some of the other comments, and there's fools posting to him that his machine doesn't work; and that the coil ideas are bogus.  Crazy.  I'm impatient though, where's the receiving half?
Like this schematic still requires a 15V and 24-220V input..... But I recall something about 3 parts so I guess I'm impatient :)
Schematic updated transaltion; this is one version; but the other has a 555 timer and override IR2113 driver attached for start/stop circuit
The other had better text than this one; just fixed TT translation and a few minor things.
