Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
WFT,  if you have it assemblied please try to see if there is any connection from the disks to the hemispheres.  Try every type of energy you can, such as wind, heat, magnetics, battery, cold, etc..
You may think of other types as well.  Remember that the final collection may not be in the same form as you start with.  Magnetics may become static electricity for instance.
I am asking this due to seeing may devices that first have to be "primed" before they begin working.
I am beginning to flow chart Bashar's description will side notes of his actual transcripts.  And also hope to find his other works to compare meanings from.
Hope
Just a note:   to me looking at the transcript,  there are two insulating layers of crystal materials not one.  And Electromagnetic energies are the main force to attract.  I would place a magnet nearly touching each hemisphere with north pole towards one and the south pole near the other to attract (draw) those forces toward.  I believe though there is more electromagnetic charges than mere ferrous metals show.  So this suggestion may be premature.  Ed Leedskalins may have known how to separate these already and use them independently.  Hope beyond hope that you will discover the same things.  How you orient the device to the north/south poles just might have bearing to the successful outcome of these experiments.
WTF
I'm still wiring the net at the moment, as the original one wasn't a proper Fibonacci spiral, it had the same number of spirals on both sets, but my new one has 55/34, I've wired all the 55s and have just started the 34s, this will probably take a few days as the wires a very close together, then I still have to drill new crystal with the holes, after I have done this I will post the pictures whether it works or not.
Also I was thinking when Bashar said interwoven, did he say interwoven as a meaning of translation so we would understand the double spirals are combined, or is his spirals made that way, because if his are made that way then I'm thinking why, when they would have the technology to fuse it together or cut it out of a flat plate of gold which I'm sure they have an unlimited supply of.
So I'm thinking when something's interwoven it has a up and down pattern like a EM waveform if that makes sense, so maybe It needs to have that waveform pattern so when the energy courses along the same route it gains energy. I know I'm probably thinking out of my arse........ I stop thinking now.
Hope
Interwoven:
v. in·ter·wove (-wōv′), in·ter·wo·ven (-wō′vən), inter·weav·ing, inter·weaves
v.tr.
1. To weave together.
2. To blend together; intermix.
v.intr.
To intertwine.
Like a cloth.
gauschor
Short offtopic: watched some Bashar videos and pleasantly surprised. I have not found a point yet where I'd say he's a scam. In fact, most of his explanations (e.g. universe, time etc.) make perfect sense (especially if you investigated these topics independently on your own). If he's fake then he's a good one. The presentations are definitely more worth the money than most cinema movies.
