How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
sm0ky2
If you want to learn how to make them:
Listen to Bruce, and build his examples
Practice
Learn how it works
Then build it the size you need for your purpose.
The shape and arrangements of components are not as
important as what is happening.
Look at the history, look at the facts, look at the original theory.
And think
sm0ky2
Test question:
1) Why is 5mm important the U.S. residential electricity industry?
Toolofcortex
Ok smoky stop confusing people.
Bruce_TPU
I'm not there yet but smoky was right on about the needed precision for the three frequencies.
I'll tell you what I think and give y'all a new nugget to chew on..
Did you know that it is possible to create a revolving magnetic field with these electrons?
I've done it. But way to slow. What if someone were to change Hertz to linear velocity?? And what IF someone then used mathematics to change linear velocity to angular velocity?
What if you wanted to make your angular velocity to be CLOSE to the speed of light but not 299 or the collector is destroyed so instead you tune just off of that to say 245?
Then what if you hit the needed three freqs to match the angular velocity needed to hit 245 MHz?
If each of the three freqs had a  component so that together each hit the angular velocity that gives a rotating field at 245 Mhz, you'd end up with three collector pieces each with rotation CLOSE TO the speed of light.
The math is there. And the input freqs would change with diameter due to the change of angular velocity.
So the three freqs would then have a mathematical purpose and intent to speed rotation. And not just arbitrary freqs.
But I can tell you this..
Certain freqs related to lightening have VERY STRONG magnetic fields that can be tuned into to generate a little electricity. This is where you must start by having the kicks interact with those magnetic fields.
My problem is I'm still throwing rocks instead of shooting bullets. I need SPEED!
Cheers,
Bruce
Bruce_TPU
Sorry.. Double post from above..
