Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
gammarayburst
Quote from: LibreEnergia on February 11, 2015, 04:26:27 PM
I'd fund it, if you could quantify the above statement with accurate measurements.
LibreEnergia, Thanks for your offer. This Hybrid material design I posted would have to be funded and tested first before I could do a work in to work out measurement. The material if it proves to work as planned would open up a whole new area of magnetic research and development. It would make Pseudo Solid designs have a very large ratio of work in to work out. Only one small bar segment would need to be built to prove the theory.[/size]
Thanks, Butch LaFonte
norman6538
Butch I just hope you finally get one of these ideas working well. I have tried some of
your ideas and all I ever do is shift the sticky spot or reset problem around to different
places. Its easy to make magnets do work but then you have to reset everything back
to repeat another cycle and I call that the "reset problem".
Good luck Butch.
My basement is just too full of failed embodiments. - seriously....I have 4 folding tables
with experiments and parts all laying out in the basement. - good thing there is plenty
of room down there.
Norman
gammarayburst
See attached drawing,
Note: Both rotating switches can share a common shaft by curving the lower switch assembly around to the back of the upper switch assembly.
norman6538
I don't get it Butch. Can you give us a good written description of how this works and what it will do?
Just because the flux can be switched does not accomplish anything useful that I can see.
Norman
gammarayburst
Quote from: norman6538 on March 04, 2015, 08:57:30 AM
Norman
Norman, look at the two coils. When the flux leaves and enters the coil cores it will induce a voltage/current in the coils just like in a transformer. This will not effect the rotation of the switching rotors because they operate in a Pseudo Solid fashion.
Butch
