Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
gammarayburst
See the attached drawing.
Option 1
Notice that the magnetic fields of the two long sectioned bars would be distributed in the air for their full length.
So the field strength of the two magnets is spread out and at the right end of the bars would be very weak as compared to the two magnets being between only four bar sections.
Now move the two far right end bar sections by pulling them off (magnetic field is weak here) and move them up to the far left end and the two magnets now have a shorter path for the magnetic field and will pull the bars sections in. Now move in Pseudo Solid fashion the two magnets to the left and repeat the sequence.
Option 2
After moving the two magnets to the far left, the two iron bars of one magnet will be in repulsion to the two iron bars of the other magnet.
Let them repel and move the repelling magnet back to the right end and it's field will be stronger that the field of the long bar end sections and it will be pulled to the long bars section. Now move the two magnets to the left down the length of the long bars in Pseudo Solid fashion to the left end and repeat the sequence.
Note: The longer the length of the sectioned bars, the weaker the magnetic field will be at the far right end.
Thanks,
Butch LaFonte
Floor
@Webby
          I like the design you demonstrated to, and  I'd like to see it built.
                    cheers
                          floor
Floor
@gammarayburst
               Regarding the second file ("LaFonte engine") I uploaded.  There are no written descriptions of the forces and movements in the drawings. The file was intended to be a companion to the "Pseudo Solid explained"  pdf. I thought the interactions would be clear to some one who had just familiarized their self with the principles as stated in the other file.  Other wise the "engine file" would need to explain every thing already present in the Pseudo solid file again ?  Might be better if a reader has to put at least a little 2 + 2  into it.  Working some of it out for one's self, I think, gives at least a little guarantee that one has understood ?
        floor
Floor
@ Gammarayburst
          Nice and clear explanation in that last embodyment of the PS principles. (Your last drawings above)
                                         cheers
gammarayburst
Pseudo Solid Operation With Varied Field Distribution
Butch
