Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
gammarayburst
Quote from: webby1 on December 16, 2013, 04:22:11 PM
This is the idea, but this one is using attractive mode instead.
When the upper magnet is over the piece of steel with the other magnet on it they loose most if not all of the attraction for the other piece of steel, move the single piece of steel out and over to the other side but with a fan type of separation, touching on the side away from the rotating magnet, move the piece of steel with both magnets over it forward and then slide the magnet over to the other piece of steel,, the rotating magnet seems to stay still and a slight pull brings the two pieces of steel together and then the rotating magnet moves over to the piece with the other magnet on it,, rinse and repeat.
modButch is the end position
modButch2 is the start position, so from here you slide the end magnet over to the other piece and the gap will close and then the rotating magnet seems to like to move over to that piece of steel.
It may just be silly idea,, but a distraction is a distraction :)
Webby,
I'm having a little trouble seeing the operation of the rotating magnet and how it is structured? Could you make a short video of it operating?
Thanks, Butch
Floor
Gammarayburst
          Here is the  most recent draft, again for your review / corrections / preferences.
          Please find the attached file "Pseudo solid explained  -5" PDF
@ all readers
This last draft gives additional principles and explanations of them.  Educational to novices, good perhaps as a refresher to the more experienced.  I hope it is clear and simply stated enough  that it will be a helpful reference.
                                                            sincerely
        floor
Floor
@Webby
I think your last photos made it clear, I can see the cycle. cool
                    floor
gammarayburst
gammarayburst
Quote from: webby1 on December 18, 2013, 05:29:42 PM
Floor,
Glad I could clear it up a bit :)
Butch,
I have not tried this exact setup, but ones that were close had the feedback from the field dilation equally displaced against both sets of moving magnets.
In other words,, the two moving magnets would push each other out of the way and away from each other.
I have most of my magnets tied up in a few arrays that I am playing with,, they are fun,, interesting is that when you stack 2 together in attraction the outside field gets weaker :)  Nothing new,, just fun.
What was the air gap between the magnet poles and the steel? I'm referring to the magnets that moved in Pseudo Solid fashion.
