Super simple way to see proof Pseudo Solid principle works using ring magnets
Started by gammarayburst, December 03, 2013, 04:51:41 PM
norman6538
Quote from: Floor on December 18, 2013, 01:02:52 PM
Gammarayburst
          Here is the  most recent draft, again for your review / corrections / preferences.
          Please find the attached file "Pseudo solid explained  -5" PDF
@ all readers
This last draft gives additional principles and explanations of them.  Educational to novices, good perhaps as a refresher to the more experienced.  I hope it is clear and simply stated enough  that it will be a helpful reference.
                                                            sincerely
        floor
Floor, did you make this document?
using the   file "Pseudo solid explained  -7" PDF it is very clear to me that a small force used to move the magnets can release a larger force from the permanent magnets and therefore
it will be OU.  You can see that the permanent magnet attraction can be easily turned on and off which is what an elec motor does except there is a large price to pay for that switching.
But here is the challenge now. Measure the work in and work out to show that it is OU.
But beyond that are two problems.
1. closer stronger, further weaker property of magnets.
You will need a cleaver way to compensate for that.
2. You will need enough extra to switch the magnet on/off and be ready for
the next cycle.
These concepts are similar to the Flynn parallel path concepts.
But why has there been little discussion of what Butch has revealed here?
Wake up guys... He gave you the secret right in front of your eyes.
Norman
profitis
Quote frm norman:'whats up guys... He gave you the secret right in front of your eyes.'
Unquote
He gave the window but not any secret  but we are greatful for that.you have to come full cycle at a gain otherwise you remain underunity.
gammarayburst
Floor, guys, the movement of the magnets will induce a voltage current in the coil but the resulting coil magnetic field will not effect magnets due to the Pseudo Solid movement. To prove it, the device generates electrical power but if you were to put a voltage/current into the coils from an external power source it would not make the magnets "motor".
Thanks, Butch LaFonte
dieter
Hey Floor, thanks for the detailed PDF, guess I finaly understood the thesis.
Indeed some interesting conclusions and thoughts. Now for a practical application...
BR
dieter
Ok, fellas, I hope this won't get ignored entirely, cause it took me some brainsweat to come up with it, plus some graphics fiddling on a pc that lacks of photoshop.
This is my contribution to Butchs' work and as far as I see, there is an energy gain.
Some details...
A certain force is required to bring the rotating magnet in close proximity of the static magnet, but the same force will be given back when it has passed by, although the force will be given to the rotor.
The rotating magnet is rotated by a motor, not drawn here, tho the shaft is visible.
In stage 5 the rotor will be held back, which compensates the gain of stage 4. Yet there is 2x gain in stage 2 and 3.
Of course, the rotating magnet(s) and the iron must be synched somehow, eg. by gears. There may be multiple rotating magnets, depending on the diameters of both rotations.
Is there a flaw?
BR
