Telekinese forces proven...
Started by hartiberlin, August 17, 2006, 04:10:54 PM
Nadda
Teleportation is a name for a singular event but the method to achieving that event is probably plural. A person can transport from one location to another in many different ways, im sure an object could teleport by just as many different means. I also read a portion of that document on teleportation and its very interesting. Invisibilty is not a hard task to accomplish, everything we see in our spectrum exists within specific frequencies, manipulate an objects vibrational frequency beyond our spectrum and you not only transform it from solid to transparent to invisible but you would fundamentally alter the state of its matter and reduce its mass index. Combine that objects altered state of matter with potiential telekinetic force to easily move an effectively weightless object, would appear to be teleportation.
Although the object would essentially teleport, it would still remain within our dimension just simply outside of our eye spectrum. Unlike classical teleportation the object would not be deconstructed one atom at a time, transported beyond our dimension and reconstructed on its arrival to its location instantaneously, it would be different means of transportation and states of matter. It seems to be a direct conflict similar to particle wave theory. This form of altered matter being achieved by wave form instead of particle form. Perhaps both are possible, or exactly the same. The public hasnt figured that one out yet.
Using telekinesis as the driven force to move the altered objects would be relative to some of the effects noted, such as the transportation not being instantaneous, the distance not being great and direction apparently being random. I just re-read a couple of paragraphs of the document, and as of right now im fairly certain this is exactly how it happened. Those effects noted are spot on with what i would expect to see.
@triffid, it has nothing to do with animals, only matter.
triffid
Even if "the fly"had been a true story I would not wreck the lab or the equipment in it.Wrecking the lab was a way to keep the public intertained. I guess teleportation would have a lot to do with the human animal?triffid
