1lb lift-force anti-gravity from ordinary charged capacitor!
Started by leviterande, December 17, 2013, 12:39:17 PM
leviterande
The paper from 2004:
Highly interesting yet this paper is never discussed anywhere.
http://www.space-mixing-theory.com/article2.pdf
The experiment done by Dr. Doyle Buehler on just ordinary insulated 1ft  parallel plate capacitors. polarity up or down doesn't matter. Weight is reduced. As you can see from the paper this is not ion wind, not electrostatic phenomena, not repulsion of Earths negative field. This is only real  true anti-gravity weight reduction thus far seen by me.
I have read and researched quite a bit in this field and done even more testing & experimentation with homemade relatively powerful parallel plate capacitors but not once have I got a 1gram weight change.(single plates lose weight however) Is my equipment that poor? or Doyle Buehler´s paper made up which would be very strange?
As I understand, a parallel plate capacitor/single plate capacitor should lose weight depending on its energy stored. Doyle Buehler tested different sized caps. All lost some weight. He noticed that "weight -change" increased exactly proportionally with energy stored in capacitor. In his final 7- joule cap. weight reduction of 380grams or nearly a pound was registered.
We should pursue immediate investigation into Doyle Buehlers claimed results , this is not an 93 year old experiment where all threads are lost and this is not an measuring error and the results are not tiny once -in- a- while sub 1gram, but are solid huge  weight changes.
I have contacted him but I havent got an answer from him yet.
If you have any earlier experience with this please share.
synchro1
Honda corporation did extensive experimentation with this effect. They immersed capacitor plates in mineral oil. Although registering weight loss with charge, nothing as dramatic as reported here was noticed.
http://jnaudin.free.fr/lifters/musha/Musha.pdf
leviterande
Quote from: synchro1 on December 17, 2013, 02:17:56 PM
Hi synchro1,
yes indeed, and this also confirms the whole thing.   I know this paper and I have actually long ago calculated the  energy/lift ratio stored in the Honda  capacitor and I believe it turned out roughly  the same ratio as  calculated from Doyle´s  paper  thus matching the 0.47N per J.  One  thing noted however came to my mind a couple of days ago  that may actually be the reason why I didn't get any results.
I know this is going to sound plain wrong, but Could it be the half wave output feeding the capacitor , I mean that the feeding  of the cap was somehow oscillating. yes a cap is used for ripples so it shouldn't matter but who knows  in this area of research.  Anyway  I used a DSt Flyback.
xee2
leviterande,
Thanks for posting the link to the PDF. JLN Labs posted some similar effects several years ago. I tried to replicate some of the tests but did not see any change in weight.  :(
d3x0r
Interesting; my theory wasn't so far fetched ; far from complete but not out of the ballpark.
