I need input
Started by lonemoon, January 07, 2014, 12:00:26 AM
e2matrix
A little searching found this on a facebook page.   I don't do facebook but someone might try contacting them for more info.   It appears it is related to HHO.   Note they refer to the "fuelless 25,000 watts G-25KW Power Module" as in the Advertisement above :
"https://www.facebook.com/DazoHydrogenHhoEnergyPhilippines
DON BOSCO TECHNICAL SCHOOL IS USING WATER FUEL FOR CARS & 25,000 Watts Unlimited Free Energy! Actual Demo Presentation live inside campus ground...
Neptali BermudezCarlito QuilangCarlos A QuimsonJr ColladoRex Cyrus J. Cantimbuhan,
Kapitan Dazo Water Car Fuel & 25,000 Watts Unlimited Free Energy
https://www.facebook.com/DazoHydrogenHhoEnergyPhilippines,
"On Demand" Hydrogen technology, its use in vehicles, the recent advances, the challenges we must overcome, and where the industry is headed, was a great honor and very exciting to say the least. We have been involved in every aspect of this technology since our founding in 2008 and even before that, when there were only a tiny handful of garage inventors just beginning to manufacture their own versions of hho kits. Now, thanks to the internet, YouTube, and the ability to share the technology around the world, interest in the subject has exploded around the world. Because of all the inventors and engineers building and experimenting, A lot of advances have happened in the last 4 or 5 years and I can assure you, more are on the way from Solarman Dazo or send an e-mail to : dazo.solarman@gmail.com..or call : 0916-233-2324..we are now in the Philippines and ready to export our " tubig na gasolina " or HHO all over the world...
NO CHARGING FROM THE SUN, NO GASOLINE, NO DIESEL, NO BROWNOUTS..Philippine Patent .
25,000 WATTS FUELLESS G-25KW POWER MODULE
The Unlimited Energy Server is a New Generation solution that is clean and reliable. It can produce clean energy 24 hours per day, 365 days per year, generating more efficient power than intermittent solutions, and delivering faster payback and greater environmental benefits for all. The Unlimited Energy Server systems are easy and fast to install, practically anywhere. Independent Power in any weather 24/7/365, Brownouts - Free.
Super Efficient that can support motorized devices such as aircondition, high watts water pumps, power pumps, power tools, etc.
The Unlimited Energy Server components within and how it works:
After switching ON from the safety panel, the starting battery source block will trigger the relays from the conversion block to engage voltage amplification and to stabilize the flow of current supply by switching relays to the electric motor.
Once the voltage stabilization complete the electric motor starts the alternator motor to spin via computed size ratio pulleys and belts with an automatic tuning capability the revolution per minute (RPM) will be monitored thru sensing circuits that automatically adjust to correct the direct current flow when if need to build a regulated magnetic flux and produce but stable electricity.
And when the Alternating Current is ready , the stabilizer #2 block enabling another relays by switching DC power source from the voltage converter block and feed signals to enable the Loop mode by magnetic contactor. While closed loop sequence engage, the device automatically collects and store all excess/heat waste energy to reuse it again and again , preventing the electric motor from stopping , this is the same process on the isolator block receiving power to change the batteries from maximum full level to standby float mode. The stage process is happening within 15- 30 seconds after pressing the power button. And after that you can now use the machine....
Watered Powered Fuel Cell , the system processed ordinary water, separating the hydrogen & oxygen, then utilizes the hydrogen as its fuel. The system used is a hydrogen gas generator , powered by a 12 -volt battery. The system produces hydrogen gas and oxygen from water on demand. The invention produces hydrogen gas & oxygen from a water on demand. The energy carrier gas is naturally aspirated by the engine vacuum via fuel line system, the system is replete with controls for hydrogen gas to propel the engine & deliver the horsepower speed and torque , needed for different velocity & road gradient, because hydrogen gas is produced on demand, no storage for hydrogen is needed thus eliminating the risk of explosion in the event of accidental collision."
e2matrix
While that mentioned Don Bosco technical institute may be in the Phillipines and Rwanda I see there is also one in Rosemead, California.   That might be a good starting point for some email questions to see if you can track down more on this.
