Lenzless resonant transformer
Started by Jack Noskills, January 17, 2014, 04:58:15 AM
forest
Quote from: zcsaba77 on January 19, 2014, 03:29:30 PM
Hi T-1000
What is on picture on left upper black box?
regards zcsaba77
It is Bertonee neon sign transformer.
zcsaba77
Quote from: forest on January 19, 2014, 03:35:52 PM
Hi Forest
This transformer work on 12VDC or 110/220VAC?
regards zcsaba77
forest
Hard to guess, there are various models like that one  http://www.ebay.com/itm/Bertonee-replacement-neon-transformer-04-10947-Cirqus-Voltaire-Star-Wars-Ep-1-/331099247325?pt=LH_DefaultDomain_0&hash=item4d170d92dd
Don presented a table top device with inverter so his spark coil was probably 120V rated. He has also a kind of voltage regulator because his nst output was 9kV while he used capacitors for lower voltage.
Jack Noskills
verpies: It most certainly is OU, but I have no meters so I cannot say how much. But how much OU is not important at the moment, the working principle is.
My cell phone camera is broken, it refuses to enter in picture mode. Something wrong with the manual switch.
I have nanoperm ferrite which I got resonance effect. Haven't tried with iron because I don't have enough capacitors. I have read that for iron maximum frequency you can use is below 500 Hz.
I have also one small E-I ferrite core from a printer. With that I got OU without using capacitors, just shorted the coils to itself and no resonance effects. After this I started using nanoperm because it was bigger so easier to work with and begin playing with capacitors.
I am using audio amplifier so it can give enough push (amps) to the circuit. If someone is using signal generator they typically do not give out amps so the only way to magnetize the core is to use higher frequency. I think this very effectively rules out iron. You can still look for resonant frequency with signal generator from iron tho.
I have only light bulbs for load. Resonance is disturbed only if load is capacitive but I don't think this matters too much. If there would be only one secondary coil (like in the Utkin paper) then it would be very sensitive to capacitive changes in the total circuit, also resonant frequency would be much lower. In my tests the sweetspot in the output is several kHz wide so it is not necessary to find exact match. Most important is to tune the primary so current consumption is minimised in the driver.
When secondary coils oscillate, they create power in the LC-circuit which is then used by the load. So, when magnetic field collapses in the output LC-circuit, current reversal occurs and it rushes in the other side of the capacitor. Any load in its way gets powered and as a bonus energy is increased when other side of the capacitor is reached.
verpies
Quote from: Jack Noskills on January 20, 2014, 05:57:16 AM
verpies: It most certainly is OU, but I have no meters...
How do you know without meters?  Did you loop it an witnessed a self-runner?
Analog power amplifiers are good devices to apply stimuli to various windings.
However Amperes are not units of power.
Incandescent light bulbs make reasonably good power meters if they are the sole load at the output of a device, ...especially if they have non-coiled filaments.
Do you compare the brightness of your light bulb with the brightness of another identical light bulb supplied with DC or use a Wattbox (Bulb->DarkBox->PV_cell->Voltmeter) like Grumage ?
Most importantly: How do you measure your input power with a light bulb?
Do you realize that a 12V 20W light bulb can pass 100W of electric power at 325V, ...without even lighting up ?
...because of this.
