Free energy device Romania
Started by xhacks, January 24, 2014, 06:38:25 AM
DilJalaay
Hi,
is this your schematic?
As i found exact same schematic on a russion forum. it was Ustanovka10kw, who posted the schematic and his video.
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/134698-ustanovka-10-kvt.html#185968
could you please explain?
Regs,
D.J
cicalac
salut
why russian translation?
Adrian also
If you actually have an OU / Free Energy device with electrical input and output, there is a relatively simple way to prove it, without an oscilloscope. You just need to build two identical units and run one from the output of the other one, and run the first one from the output of the second one. Once the loop is started, remove all batteries and stand back.
xhacks
I will try 2 build 2 devices as TinselKoala said....:))
TheCell
@xhacks
for the first evaluation it would be sufficient to know the volts and amps at the battery and the bulb.
If the results are promising, I would use a step-down transformer parallel to the bulb a fwbr and a voltage regulator (that work like pwm/like used in cars and don't dissipate heat) to loop the device.
First you must be sure that the power drawn from the battery is much lower than the power dissipated by the lamp at a given voltage of the lamp. First lets assume that you have a sine wave at the lamp. Btw I don't see the HV-Part , the spark gap...
