GEM = God's Electricity Multiplier
Started by that_prophet, February 06, 2014, 09:19:10 PM
that_prophet
GEM=God's Electricity Machine
Free energy is so simple,
That we have missed it.
In our looking for such complex ways to fight friction costs.
We have failed to look at simple geometry
How you can multiply your rotations with changing the size of pulleys
Please remember, with electricity, more rotations is more power
Free energy has been discovered = (this is a Gift from God)
- By a Born-Again pre-Trib Saint (pre-Trib began early 2012),
- Scriptural Proof we are allowed to know these doors/deadlines (Mat 24:33)
I call this free energy machine a GEM = (God s Electricity Multiplier)
This one_christian_warrior was shown this Miracle by the God of our Holy Bible
- from The God of the Bible = (Father +Jesus +Holy Spirit)
I believe this might be because I asked our Father for something to help others,
- + not for myself = ( though it does bring me great joy )
I have always wondered about how I could help my future Tribulation Saints
- So I asked for some way to help these Tribulation Saints be better
- - Able to survive easier, so they can make it past the Great Tribulation
- When they would have to survive our Canadian winters
- - off the power grid
He first showed me a Vision, of a ten-speed bicycle going up + down a hill
- Where if you drove up the hill in tenth gear, (few turns of the pedals)
- - Then back down in first gear
- - - You would do far less pedaling up the hill
- - - - Then pedal like crazy all of the way down
- - With electricity, more rotations equals more AC electricity (power)
Then, as a confirmation, that this came from Good Forces = Holy Spirit
- + not bad ones (fallen angels)
- - I found it described in Ezekiel 1:16,
- - - Where they were trying to describe the workings of a UFO:
- - - - Or chariot of fire (2Kings 2:11)
When you take a careful look at this technology
- It seems obvious (the more generators you add, the greater the multiplication factor)
- - You put power into a motor with a large pulley
- - - Which you only have to turn the one single turn (very little energy)
Then you take power out of the one to a hundred small pulleys with generators
- That you attach to the same belt
- - Each generator rotates tens to hundreds of times faster
- - - Each rotation gives you electricity (lots of energy)
- - - - It is truly that simple
I believe that it can't help but work
- Then why has this simple method of gaining free energy been hidden for so long
- - It is because Satan + his evil spirits are working hard hiding this
- - - How else do you explain this not being discovered earlier
- - - - Like, as soon as electricity had been discovered
- - - - - This is soooooooooo simple
- - - - - - Why has it been hidden
Well, it is hidden no longer. I have published for all to use freely
- at : http://free-energy.yolasite.com/
+ what I heard on the web
- - that if a person publishes something on the web
- - - and chooses not to patent it, like I have done
- - - - then it opens it up for all to use freely
- - - - - without having to pay any patent fees
I have this, and two other unique ideas given me by God that I have published
- On the web at this website http://beliefstoliveby.yolasite.com/
You use pulleys to multiply your rotations
And with electricity, more rotations is equal to more electricity
The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are multiplying the power.
We don't need the air polluting effects of the combustion engine any more
We have self-generating electricity generators
That can be made to practically any size or voltage
So that we have the choice to have almost everything self powered
I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.
I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
I figure that if you keep adding output generators to the belt
then you would eventually generate enough power
to make up for the power that you are putting into the drive motor
as well as any losses due to friction
until you add enough output generators
to have not only have a self powered machine
but you can get an excess of power as an output
= free energy output generator
Here are a few of the reasons for this system to work miracles
- The massive circumferential differences between a large drive rotor
o You put power into turning a motor only once-(lg)
§ When the power out generator(s) spin hundreds of times faster
· Each rotation gives you power to put back into the system
- Then you could add tens of these output generators
o All of these would be turning the many hundreds of times faster
- Them you could enlarge the drive motor pulley to the max
o As well as shrinking the size of the pulleys on the output generators
§ to make the multiplication factor even more
- So lets see, you are putting energy into the high torque motor with a large pulley
o And then through extreme size differences in pulleys
§ As well as the simple addition on 10`s if not 100`s of generators
· You get your many generators to spin many rotations
o That you are getting power out of
§ While your input motor only turns the once
· You have to make power
You need one DC motor as an input motor
Then you need at least one AC motor as a generator
This is one of the easiest way to multiply your input power
By adding additional output generators
on the same belt as your input DC motor with the one large pulley
Or, you could change size of the pulleys is another way to effect your multiplication
by shrinking diameter of output generator(s) pulley
or increasing diameter of DC input motor pulley
are other ways of increasing you multiplication
the drive motor and all of the generators could be any voltage
as long as they are of the same voltage
you might need to use voltage regulators
to keep this contraption running smoothly
Maybe this mechanism should be called an electricity multiplier
As you always need the initial amount of electrical power
To be multiplied into your gaining of free energy
Which can be initialized by giving the large pulley a turn by hand
this is a Miracle from God
yes, it does indeed work
using size change in diameters of pulleys
to multiply the rotations of your input motor
by the large change in circumferences of the pulleys
as in, the multiplication factor is due to
the tens if not hundreds of times the circumference changes
I just don't like the idea of somebody blowing up a battery
And maybe even catching fire
Now, most likely you will not be interested in this Spiritual part
But I discovered this by praying and asking the God of the Holy Bible
for a way to help us earthlings, the Tribulation Saints mostly
Especially during the 3.5 years of the Great Tribulation
Where they will need a way to survive our cold Canadian winters off the electricity grid
Don't believe in Satan or evil forces
Please explain why this simple idea
Of using change in size of pulleys to multiply electrical power
Has not been discovered all ready
to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters
WARNING = the pre-Trib started on March 14th, 2012
http://doorschristmustpassthrough.yolasite.com/
joe lynch
one_christian_warrior@yahoo.ca
Diagrams of some uses for this technology are at:
that_prophet
And with electricity, more rotations is equal to more AC electricity
http://lie .yolasite.com/
joe lynch
( ok, I know that most will fall for satan's LIE, the religious belief of EVilsOLUTION )
that_prophet
IT IS TRUTH
From Jesus, the God of the Bible
Just think about it this way
You are only putting enough electricity into the drive motor
to turn the DC motor one revolution, (extremely minimal)
+ with then with the large size of the pulley
even the one rotation gives you lots of belt distance
Then there is the minimal circumference of your output pulleys
giving you the maximum rotations for each of your output generators,
- - (tens to maybe even hundreds of times of the drive motor)
- - - - < + we can have multiple output generators just by having a larger belt >
oh yah, did I mention that your easiest way to multiply your electricity
is to add as many output generators as you can fit, (or afford, lol)
YOU MUST GAIN,(nultiply) LOTS OF FREE ELECTRICITY
GIFTS GOD SHARED WITH THIS WARRIOR: to share with the world
I have these three ideas, that I strongly suspect was given me by God + I have published
- on the web at this website http://beliefstoliveby.yolasite.com
- - Along with a list of my beliefs
- - - And other things that God has shared with me
- - - - That I would like to share with the world
- - - - - WARNING = I AM is the Name of the God of our Holy Bible
everyone breaks the 3rd commandment
when we say "I am"
we are taking His name in vain
notice how movies + shows on TV use it often
why are all commercials using the "I am" now
Satan knows very well not to use it
Why do you think products are being sold by His Name
FIRST GIFT) –<in 88> next generation joystick (has 6 movements instead of 2)
(In a Vision which God shared me the week of my becoming Born Again)
- Detects motions in all three axis's
+ Detects rotation in all three axis's
- - plus there could be 6 more activating movements
- - - 2 for a small joystick for the thumb
- - - + 4 individual switches for each finger
that is 12 more motions detection
- equalling 24 in total
- - that is 12 times the regular 2
- - - of a normal joystick
- - - - I thought this was quite the Gift
(then He showed me this awesome virtual reality video gaming room)
SECOND GIFT) – <in early 00s> 3-D virtual reality games room
(In a Vision given to me sometime in the early 2000s)
- Where you are in an eight foot cube room
- - With videos projected on all four walls
- - - The ceiling + the floor
- You are held in the centre of the room by four cables
- - Which go from your belt to the four corners of the room
- - - Holding you in the centre of the room
- You are standing on a ball bearing mat with motion sensors
- - So that you can walk or run in place
- - - While to video moves by you on the screens
- You are wearing a skin tight suit with markings all over it
- - So that your body movements can be captured by the game
- - - Through sensors in the room
- - - - Then translated into game extra movements
- - - - - for fighting with your hands + feet
THIRD GIFT) – <about 2005> Free Energy
<<< these gifts are free to use by anybody = no patent fees >>>
Magluvin
Hey Prophet
Have you built one yet? ???
It takes a lot of input energy to turn a generator when its output is loaded, let alone 3 or 4 gens, and, let alone using a large pulley on the motor, with small pulleys on the gens, it multiplies the load to the motor, and less torque to the gens.
I believe in God, but this setup is a hard sell. ;)
Mags
Not again!
This is the electric wheelchair guy, with yet another username.
Hey Prophet: You should talk to your God and ask him how he feels about people who make claims they cannot back up with data.
