mrwayne
Quote from: mrwayne on April 09, 2014, 08:03:02 AM
How to do work without consuming all the energy... 101 ZED SYSTEMS
#1. Bring the load (output) to equilibrium... We call state precharge, it could also be called floating.
#2. Raise the water level and watch as the load equalizes with the new water level.
#3. Notice that two things have occurred.... the load has changed orientation and the water level has increased................
#4. In the ZED - the load is hydraulic output - not weight - so every time the water level rises - the result is hydraulic production.
#5. In the ZED - we push down to go up...... That "clue" was to show that every layer added - doubles the rate at which the water level rises (which results in decreased volume required).
#6. At the end of stroke - after production - all the head - including precharge is still in place.
#7. The LOAD IS LIFTED WITHOUT CONSUMING THE HEAD.....
---------From that point.... you just have to see how good you can design a way to reuse the HEAD.
The ZED layering system increases the head with continued displacement - NEVER in the process do we float up like a balloon under water - our "Neutral Load" just follows the water level.
Wayne Travis
Oh my, Mark and minnie
Obviously not simple enough ... Output is at step #2 Work out without consuming the work in.....
Hope that helps
MarkE
Quote from: mrwayne on April 09, 2014, 09:16:29 AM
Hope that helps
Calling things output that do not deliver energy to an external load is just lying Wayne.
mrwayne
Quote from: MarkE on April 09, 2014, 09:24:26 AM
Call the output whatever you like - Sir. I am done with your word twisting and games.
minnie
   The only output from you Wayne is words.
    You have not shown ONE thing which is in support of your claim.
    Just provide a decent description if you want to be believed.
    Trouble is I don't think you can - there isn't one.
                         John.
mrwayne
Quote from: minnie on April 09, 2014, 10:10:50 AM
                         John.
SO sad....
You missed it again..
I am done with you "Minnie"
