mrwayne
Quote from: LibreEnergia on March 03, 2014, 01:50:39 AM
I'd wondered why Wayne stopped at having just two devices connected though. Using his thinking adding more connected together would offer far higher chance of success. Even in its current form, with a bit of pre-charge the IZED, (infinite Zed) might actually work long enough to convince investors it worked. In fact it would be hard to argue that it didn't.
The design of the system was just to mechanically amply force - by request we spent the money to self loop itself - even in its infant stage of development - with no engineering - that was possible.
Once again here is the link to that self contained closed loop system
http://www.youtube.com/watch?v=q-0TITC4Wrc
The arguments will always come from some...
Thank You
The Working system is not what was needed in the end - to gain the funding - it is character, our actual business plan, and the simple math - and blessing from God.
Thanks.
Quote from: mrwayne on March 03, 2014, 09:05:13 AM
I realize you did not mean this seriously;
But you are right regarding the Set up pressures - the first time you introduce the differential density fluids - and set them up to the sunk and stroked position - that requires external input.
That input never leaves the system - and is continually recycled.
SO check ion never check out - exactly
Wayne
Then why do your machines ALWAYS STOP after a few minutes or hours unless they are driven from the outside? Still having "leak" problems? That precharge just keeps leaking away, doesn't it.
Show the sausages, Mister Wayne, or admit that you have none.
Minnie asked you a question, politely, several times. Why are you not answering him directly, without misdirection and stalling, waffling about?
I know why, and so does everybody else including Webby and LarryC.
Quote from: mrwayne on March 03, 2014, 09:15:52 AM
Thank You
Thanks.
Now you are piling lie upon untruth. Mark Dansie DID NOT CERTIFY that system as self running. It has a tummy ache on one side, to boot. And you are practically admitting in this statement that you do not in fact have a self runner any more than my Heron's Fountain is a self-runner.  You can waffle about and dodge the direct question as much as you like, you can invoke God's blessings... but you cannot deny that for some reason, God did not permit you to put up that 50 kW plant that you "expected" to be able to install at TBC years ago.
Thou shalt not take the name of thy God in vain, mister Wayne, and someday you will have to account for your Zeds and your business plan before an Authority with whom you cannot argue.
Marsing
Wayne
The bad thing so far there is no energy can be extracted from the system.
every cycle you need to allocate some external energy                  .......... ALWAYS.......       ::) :o
mondrasek
MarkE, I was going to draw your State 3 and dimension the remaining heads on the pod and each riser that need to be resolved.  But I ran into an error with your stated water height in AR2: 49.651mm.  That is obviously not correct.  Could you provide the correct value?  And you should try calculating the buoyant Forces that remain on the pod and each riser that still need to be resolved.  The ZED cannot remain in the position you show in State 3 unless restrained.  It has more Energy that needs to be released due to the still remaining buoyant Forces.
I would have liked to just present my own diagrams again, but I see you calculated the rise based on Volume in = Volume out.  This is another error since there is a third Volume of air that is interacting with the system by the nature of the outer annulus being open to the atmosphere.
I calculated my lift distance based on the ASSUMPTION that Energy in = Energy out, not by simple volumes.  That results in a stroke that should be 1.9094mm.  But the results are similar in that the system could not come to rest at that larger lift distance either.  There is still 31.828 grams of buoyant lift force at that larger lift distance.  So again, the lift would have to be even further to resolve the remaining buoyant Forces.
And FWIF, no iterations need to be performed for this simple analysis.  The iterations would be needed (for me at least) to find the final resting state of the charged ZED.  That state requires that the sum of all the internal buoyant Forces be zero.  That is definitely not the case in your State 3, nor in the one I calculated via an Energy Balance approach.
