Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
Files were oversize had to shrink them
2 Dual TD cascade.png  and  2 Dual TD,png
guest1289
It could be designed as a circular motor,   which just has 1 stator-magnet,  attracting magnets on the wheel .
      So, the single stator-magnet,  could have an axle running through it,  so that it could turn like a propellor,  and then using the  momentum  of the wheel moving( from attraction ),  that momentum of the wheel could be used to turn the  single stator-magnet 90-degrees,  each time a magnet on the wheel spins past .
(  you can figure the rest out )
______
I have also been using the example of separating, and joining 2 magnets, to explain my idea for electrolysis of water  :
  http://overunity.com/8798/theoretical-efficiency-of-electrolysis/msg473379/#msg473379
______
Also, if youre bored, you can view my  magnet-motor-1, and magnet-motor-2 ( and one or two others ) from the following post :
http://overunity.com/15774/permanent-magnet-motor/msg473357/#msg473357
Floor
@ guest 1289
Your pelton wheel application to magnetism is
an interesting idea.
I've seen some experimenters try to shape magnetic
fields as method to gain energy.
There might be something analogous to a pelton wheel
that could increase the efficiency of a magnet motor.
Its not my area of experimentation though.
The devices I build are to make measurements.  I have not
tried to build a "motor".
I'm working (for the present) under a premise that momentum
cannot be completely maintained in any process involving a permanent
magnet OU device.  This due to right angle interactions.
Energy doesn't come from nowhere.
It may have originated in the "vacuum / ether" ?
As someone one once coined it  "a firmament"
It may come from "the vacuum / ether" ?
As someone one else once coined it  "a permanent firmament"
                          Best wishes
                                 floor
Floor
Two pdf files that show the interactions in a (3 magne)t TD unit.
Useing 3 magnets is a simplification, as it combines 1 of the
return strokes with the input stroke.  This does not change
the over all input to output ratio.
1 unit's input is against replsion. the other unit's input is
against attraction. The same 19+ % greater output after the
return strokes should be present in the inout against attraction
unit, although I have not tested this.
                      Floor
Floor
This topic is a presentation of a simple Over Unity device.
The device is not a motor, and does not self loop.
It is designed to test a principle.
A particular set of interactions between 2 magnets along with the measurements
of these interaction are described in detail.
The interactions demonstrate > 19% over unity.
In its original form,  the device is presented with,  input against and output by repulsion (magnetic).
This, the latest addition to the topic, is a PDF ANIMATION of a set of interactions where in,
the input and output of the device are against magnetic attractions.
It is open source.
Yes I'm claiming that this is over unity.
Pleae see the attached "TDanimation against attraction4.pdf" below
                                          floor
