Work from 2 magnets > 19% output 2
Started by Floor, February 17, 2014, 01:53:56 PM
Floor
Hi nornam
If you look closely at / study the 4 pole 45 degree TD PDF file
http://overunity.com/14311/work-from-2-magnets-19-output-2/dlattach/attach/161475/
It becomes apparent why a magnet or magnets can be free from a net attracting force
(free from being stuck) when both an attracting force and a repelling force are acting with
equal effect.
This neutrality of attraction,  is actually a neutrality of both attraction and repulsion, because
these two forces are in balance.
In the "4 pole 45 degree TD" file, this is  ... ONLY ... in terms of a specific line.
(the straight line of pull of the inner magnets from within the outer magnets).
By creating situations where in, there is a balance between the attracting and repelling forces,
one creates what is /are  in effect, a kind of magnetic shielding.  These effects are direction specific.
It is also possible to make a magnet FREE TO ROTATE  (PassThru5.PNG file) even while it is under influence from another or several other magnets, (by creating a balance in the attracting and repelling forces).
In this situation, the magnitude of both the attracting forces and the repelling forces shift throughout
the rotation, but yet there can remain a balance between these mutually shifting  magnitudes.
                    floor
Floor
@Norman6538
Here is a file with some details.
Please find the attached "PassThru 5 Detailed" PDF.
                  Thanks for the inquiries
                             regards
                                      floor
norman6538
Thanks Floor, that helps a little but I don't see sliding that magnet set away or back
in accomplishes anything other than pushing a matchbox car on a level table.
Enlighten me please.
Norman
Floor
Ok Norman
Let me see if my Buddha scepter of enlightenment is working this morning.
When the mid magnets have been  removed from between the outer and inner magnets
           (this can be done, with out doing work against magnetic forces)
the inner magnet is compelled by magnetic forces to rotate
                   (to do work (output) as rotation by 180 degrees).
After this 180 degree rotation, the mid magnets can be returned to their first position of,
inbetween the inner and outer magnets.
            (as before, this can be done, with out doing work against magnetic forces)
With the mid magnets returned to their position of between the outer magnets and the inner magnet,
the inner magnet is free from magnetic forces which would compel it to rotate.
            (The inner magnet can now be manually rotated 180 degrees  with out doing work against
               magnetic forces, thus magically, is it returned to its starting position).  (Smile)
                       thanks for the inquiry
                               best wishes
                                        floor
norman6538
Floor, that helps a lot but it would be best to label each one and then add that label
to the text to make it very clear. And then say if the rotation comes from attraction
or repel force rather than a generic "magnetic forces".  Its my understanding that
only 2 kinds of work can come from permanent magnets
1. attraction but then you have the sticky spot
2. repel but in order to have a repel force you first have to input
work ie. squeeze (unless you have a trick to achieve that) - which turns out to be the opposite of the sticky spot.
And you did clarify the reset back to the beginning for another repeat cycle.
Thanks again.
Norman
