Motor-Generator
Started by Miroslav13, February 26, 2014, 02:21:32 AM
jbignes5
I am mid way through my replication attempt. The soft iron cores took me a bit to get fashioned and cost me 50 dollars. It is a 10 inch version. Two halves were made and the stock was round and 1 inch across.
I have the neo's for the magneto and that is about it for now. My replication attempt is halted for personal health reasons but I am getting drawings made up of the whole unit.
In the link above to the patent you can see 3 sections of the whole device.
1 Magneto (for field coil generation)
2 the Generation section. Field coils around the rotor(generating coils)
3 Prime mover(motor) <-Has to be as it shows in the patent.
All 3 of these sections are on the same shaft.
The magneto is a two pole(magnets 160 deg. NS)
The magneto pickup coils are on 4 poles (2 AC circuits are generated that way)
These two circuits then get chopped at the peaks of their sinus waves and fed to the field coils over the field cores.
The generator section is much like this guy shows but it is inverted. The field coils are on the outside and are in 1/4's of the round field core halves. 2 on each half core. The field coils should be that of very fine wire and hook up diametrically to each other for each circuit. So the circuits are 1 coil for each half of the field core. The field cores are then hooked up in two circuits to match the magneto output.
The rotor section of the generator is made of heavier wire and in the process of transformation of the high voltage field into a heavy current and heavy magnetic field creates a sort of loop back to the field cores and generates further high voltage from the heavy magnetic field cutting the lines of the very fine wire used in the field cores. The heavy rotor coils are then ran to brushes on the shaft and then goto the output and prime mover sections. They share the same output and coincidently power the whole unit via the prime mover.
In the generator section if you wire the coils correctly so that the field coils circulate in the opposite direction of the rotors spin then you get additional output at all speeds even very slow speeds.
Of course you will need to control the Prime movers speed and power consumption and Tesla cam up with many ways to do that. Either in the form of Vacuum tubes or in the form of his variable magnetic motor controller. We must understand that Tesla in 1932 did the Testing of this system after is failure to get the wireless system funded and running. This was his last ditch effort in giving us Clean and affordable energy for all of humanity.
I am betting this man knew what he was talking about and this design has done nothing but sit there in the public domain for many many years. Many have scoffed at the potential of this design. Well from the success of the OP experiment we can see Tesla WAS right! Although it is backwards in the above experiment it proves there is something to using the toroid for energy generation and if it was self generating and self propelled it would definitely close the loop.
Another person from Quanta magnetics has a version of this out already but he chose to use pulse motors in his design. Well pulse motors are great but they lack any real power or torq and hence his output is lacking. If he had changed the pulse motor into a real motor then I am betting he would have gotten the same results as Tesla did.
Everyone thinks they have come up with an original design but they are merely all taken from Tesla's work and rebranded as someone elses work. I assure you it is not original and if the OP has patents from his experiments they are only provisional and should be negated due to prior art of Tesla.
The patent Tells all there is to be know about Tesla's work. The only thing left out was the method of control of each section which actually you or anyone could peruse Tesla's additional patents to find out those methods. All of the methods that can be used with this patent are at the same site that I pointed you to earlier: www.teslauniverse.com  Click on Tesla tab then highlight and click patents. It's not a complete list but give many of the more important patens and I assure you the control methods for this design are in that list. Including the variable magnetic control for the prime mover.
crazycut06
Improve your health first before continuing,  ;)  Only just now that i've learned that using a toroid for generating power was from tesla,  from the link you posted, so much to read! thanks!
jbignes5
Quote from: crazycut06 on March 06, 2014, 08:21:37 AM
Yeah and don't take my writing style as a bash on anyone. He is partially right in the effect he is seeing. But if we can get this working we need someone to take the plunge and build this sucker. Plenty have done it already or nearly a lot. My own experiment is on hold for a bit.
Others have been seeing strange effects from toroidal generators. Most stick it in the Anomaly bin and never look at it fully. Thane Hinz, I forget his last name, did the same but his discovery was high voltage transformation within a high current coil. This raised the output by looping through the induction portion of the fields and this raised the output.
Lasersaber has done work on straight pieces of ferrite and has gotten excellent results in his most simplest circuit yet. Check him out.
crazycut06
I've been slowly (pain in the arzz)  ;D winding a small toroid, divided into 4 section, trying to replicate quanta magnetics T2 gen. My rotor has 4 magnets gradually increasing in size, to get the desired output voltage, i'm doing this slowly if time permits...hope to show if i succeeded... Thanks...
Cc
gotoluc
Hi everyone,
I made a small replication to test the basic effect but fail to see any advantages.
Link to video: https://www.youtube.com/watch?v=cQ_Fo7GNfGs
Luc
