Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
T-1000
Quote from: forest on March 06, 2014, 02:20:27 PM
Number of turns in original schematic was marked as 15 primary and 45 secondary using 0.75 mm wire diameter. Also there is shield of 1 turn not closed copper mentioned. The most important part is the comment from Akula on Russian forum before time when others ridiculed and irritated him. He said Melnichenko is the key and the good inside look of how electrons can be moved in circuit. It confirms my feeling that electrons are not the source of electric current, but that's too much guessing for now. For me the schematic part which uses both comparators inside tl494 chip is a strong tip for reliability of method. Somehow Akula expect voltage rise on input capacitor C11 and need comparator to limit that value to the safe operating condition. The second case is watching voltage drop across load in this case probably it continously check for zero voltage difference between ground and the point just after bank of diodes. If each diode drop 3V then it has merit,hmm.... I really like to see more experienced electronic gurus to validate that.
I am going to cross-link my post - http://www.overunityresearch.com/index.php?topic=2358.msg36665#msg36665
Also I do not see any benefit of comparators/etc as there is only single coil driving transistor with NO feedback to the chip. The return path you see in circuit is only logic switch then capacitor c5 is charged and doing nothing after when ciruit is running as 10 microF capacity is way high value for high frequency circuit.
The secondary L2 coil is attached to the plus side of circuit and is being voltage stabilised to 12V with filtered high frequency as well.
Cheers!
totoalas
I saw in the video there was a gap in the core .....right side only????
a.king21
Can someone who is Russian speaking inform Akula about this thread in his  honour?
If he wants to contribute in Russian it is fine.
We respect him here.
havuhung
Hi All,
One weird thing with him is Akula0083: Questions about the technical issues related to the circuit diagram upload his, he will not answer, he can only for the purpose of performing his device, which has no intention to support people replicate it! . . :(
Marsing
