Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Pirate88179
Quote from: Enjoykin on April 05, 2015, 06:04:51 PM
objekt013b - one of Magic words is "GAP"  8)
The other magic word is:  Fantasy.
magpwr
Hello everyone,
I have spotted the fake just minutes into watching the original video from Lari as from the link as posted by Tinsekoala.
I have even put a comment "hint" in comment just beneath Lari's own comment "Fake".
Sometimes you guys do make my laugh.But the fun stops here since it's Monday blues over here. :D :D
Hey i am doing this so that you guys won't waste a single seconds in this "Russian version of April fool joke" which strangely seems convincing to many.
No further comment to add.
itsu
Quote from: TinselKoala on April 05, 2015, 05:23:47 PM
@Itsu: yes, your circuit is laid out slightly differently than the PC template showed, but I can tell by the waveforms that it is mostly acting the same way.
When you remove the battery and the lights go out... then you switch the switch and you get a single short bright pulse in the LEDs, yes?
But I'm wondering about your turn count. Why so many?
The yellow image below is my PCB template. I taped a piece of paper to the monitor with the image of the template from the original posting, and marked the holes, then I sketched in the traces, then I mapped the components from the schematic over to the template. Then I taped this template to the foil side of some PCB material and prick-marked the hole locations. Then I took the paper off and drilled the holes with a #58 drill bit on the drill press. Then I drew in the traces on the copper with an ordinary black Sharpie marker. Then I etched the board with ferric chloride solution. It took about an hour to make the board, from start to finish.
This was a lot easier than wiring by hand, I think, and I'm thankful that the original template was posted.
yes, when i switch the switch, i get a single short bright pulse in the LEDs
I had a length of Litz wire which i used as primary, but it is to long for 28 turns and i did not want to cut it up yet, so therefor i used this length which turned out to be 50 turns.
I will look into the PCB making, i do not have the means right now.
Regards Itsu
itsu
Quote from: Ed morbus on April 05, 2015, 05:26:47 PM
Itsu is the Break down voltage 32 volt ?
Hi Ed,  you mean the break down voltage of the diac?   It says C044,  so probably 44V?
Regards Itsu
ramset
EnJoyKin
are these the Movies that Tinsel didn't watch??
[they won't play for me??]
https://yadi.sk/i/tAW1jRzofGxiH
https://yadi.sk/i/fGeje8FzfGxgm
https://yadi.sk/i/BbzDwBhxfGxgj
Also you said
BTW if you already have Tesla Transformer you don't need a Katcher to take of power with N.Yablokov assymetirc  capacitor.
EnJoyKin
Tinsel has more Tesla transformers than Tesla had  :o
so he needs one of these>>>N.Yablokov assymetirc  capacitor.
and some of this >>>>>      objekt013b - one of Magic words is "GAP" 8)
some times its not good to be ""you are on the own. ""
when so close to the cigar...
respectfully
Chet
PS
do you need to smash up old Russian Tv's for this too >> N.Yablokov assymetirc  capacitor
or is this available to build/purchase elsewhere ?
These we have plenty of >> Gaps ,sometimes its hard to know where to put them
and other particulars ??
you seem like a nice man [not an insult =]
Thanks Grandma
