Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 79 Guests are viewing this topic.
Dave45
The powers that be already have these devices only the poor dont,
pump water for gardens, light, heat home and family, free transportation
there are and will always be people who use tools for evil we cannot change that
we all take our deeds with us when this physical existence has played out.
just a caterpillar who hopes to someday be a butterfly.
wattsup
Regarding the copper plate issue, if it is supposed to attract radiant energy, then why is it connected directly to ground? Because it is not what you say. If it was a radiant energy collector, it would have a dedicated  radiant energy collector circuit and a dioded capacitor tank instead of just dumping to ground. At most this plate is used to speed up the rebias of the copper atoms in the secondary coil to neutral, so when the primary hits again, you get maximum atomic swing hence maximum potential difference. Just pulse any primary and check the secondary, then add a grounded copper strip around the windings and see if there is any output difference at the same or different pulse frequency.
Also if the copper plate was again a radiant energy collector, from my experience it will only collect at a specific frequency that is most likely impossible to match to the primary frequency that should have already been matched to maximize output on the secondary. Of course you can always hunt around to find a primary frequency that will eventually work on both the plate and secondary but figure you will be in the 20MHZ and above range and at that frequency, you will be producing only enough reactive power to maybe light up a firefly.
wattsup
starcruiser
IS that copper plate a radiant energy collector, a shield, a reflector or a plate in a capacitor?
Regards,
Carl
energia9
if i would have the parts i would have assembled this circuit in 5 minutes on a breadboard and make tests,    i dont have the parts nor the money for them, who has them? and who is going to prove it works?
Is there anyone here who is an electronics engineer by profession and have looked at the circuit?
there seems to be many errors in it.
Google
Dave , I read your post. Really inspiring but people like Zilano and kdkinin etc just vanish from public forums once they have a working device. Humans never share their secrets because of greed and ego. Many examples galore. People join forums, learn, make and vanish, they never share their success. Others turn to fakery to gain importance. Human logic is stupid. Even dogs are better.
Best,
