Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Ed morbus
MenofFather
In Akula0083 30 Watt Self Running Generator is pach of pulses. Duty cycle is 50 precents of this pach/box. Someething like in Stanly Mayer divice. So if you not use back pach from R5 and C5 you not get selfrunning!!! And R11 must be ajusted in that possition, that be pach/boxes of pulses, or is or not is.
And how Akula say, this divice work on feroresonance.
So if you not using back pach, then you must made generator, who sends boxes of pulses. And valuses of C3 and C11 must be like in schematic, not that that more is better, more not better, can not be one, let say 2200 uF other 5000 uF, must be like in schematic.
Pulses have frenquency about 400-460 kiloherc and its duty cycle is about 10-40 precents.
Wery important wery fast close mosfet.
MenofFather
Here schematic, If you not make exatly like here, then not say, that it not works. But here also maybe something need ajust. Roman something speak about capasitor, who need ajust, but I not understand about that capasitor he speak. Or about C3 or about C13 or maybe about other? Also here is two feedback pachs, one from C5 capasitor, other from C13 capasitor. L3 inductor good be use like in picture ferite ring with tick white wire. It have about 20-30 mikrohenries, maybe 50 uH, but or about 200 or about 100 microhenries is to big, I now not good remeber.
Jeg
Quote from: EMJunkie on April 27, 2014, 08:23:39 PM
We need to start at the start! Start with something small, the least confusing, and something we have the most information on. "Little Steps for Little Feet" is what I value the most from Richard Feynman!
Hey guys
I usually don't suggest on circuits that i didn't build, but in this circuit there is something that shouts loudly!
The secondary part with diodes and C3 is the classic don smith arrangement forming a charge pump. So the most logical is to connect C3 and secondary coil (1&2), on a common earth ground so to work as a pump. After this, the ground (3) of the load, also is connected to the same earth ground to close the circuit. I would leave all the rest on battery's (-).
Dave45
