Thanks to ALL for your help!!
West East line and 30 km/s ( exist also other motion Natural fall down Law ?)
Started by tesla2, March 22, 2014, 07:35:24 AM
LASER's frequency  = 120 000 000 Hz
LASER is INSIDE ROCKET and MOVING IN SPACE ?
Fact 1
Between each line exist distans 1/120 000 000 sec
Fact 2
Each red line ( below picture ) represent axis
( the beam has got 3D shape next picure Inverse Square Law)
Fact 3
Each Rocket is moving respect to point in space
where laser was in Past (with rocket) and where
laser started signal ( energy  pack)
During time T light made distance "a" how many meters made rocket?
http://3.bp.blogspot.com/-Ol4wDyBBB1s/Ul8-MgFWSgI/AAAAAAAABOQ/LijR2GSdjv4/s1600/111.JPG
Each red line ( above picture ) represent axis 3D signal
http://www.zipheron.com/images/projects/islMeter.jpg
INVERSE SQUARE LAW - old Greece
More far  from place
where the  signal started = lower intensity of signal
( "lower brightness for Light that we registerin" )
1R = X ,    2R = X/4 ,    3R = X/9
X- brightness,  R- radius ( distance )
the same energy portion   but different  area
Laser -  -  -  -  -  -  -  -  -  -  -  -  -  -  rocket's wall
laser giving not giving light 1/120 000 000 sec
each small pack " - " growing up 3D ( Inverse square Law )
Laser <..<<...<<<....<<<<.....<<<<<rocket's wall
MICHELSON MORLEY TEST and ABOVE ?
In  books we have flat starit line
in brains we have flat line !
it is not true ! more longer arm = more big mistake
Please imagine that opposite rocket's wall
has got  many sensors.Inside each rocket
we have the same laser ( Laser's  Power is constant )
How many [Joules] and  How big area [mm^2] ???
Can we measure motion without outside
objects  for Example stars ?
p1...p2...p3...p4...p5....rocket >>> motion
rocket was in point p1 ,p2,p3,....
if distance p1--p2 = p2--p3 = p3--p4 we have conctant motion
Inside rocket we are using only C speed ( C is constant !)
C respect to point where laser started line !
SIMPLE TEST IN HOME
( 5 minutes  and You can make it)
http://youtu.be/8OnIOz_png0
explanation to above test
DISTANCE  WALL ----- CAMERA's SENSOR light need short time T
During this time T Earth and Camera are moving n space  !!!
Why  and How camera is registering Light ?
Why angle is very important to picture size ?
http://3.bp.blogspot.com/-ijRUGj2tL1k/UxA92hBKqjI/AAAAAAAABlk/WikuwqrKdvQ/s1600/1.jpeg
Picture size inside camera = that the same energy from flaslight work on biger/smaller  area of camera's chip
( brightness of the picture chage Size of the line change )
HISTORY
" Galileo postulated his relativity hypothesis: [color:#FF0000]any two observers moving at constant speed and direction[/color] with respect to one another will obtain the same results for all mechanical experiments [color:#FF0000](it is understood that the apparatuses they use for these experiments move with them).[/color]
This idea has a very important consequence: velocity is not absolute.This means that velocity can only be measured in reference to some object(s), and that the result of this measurment changes if we decide to measure the velocity with respect to a diferent refernce point(s). Imagine an observer traveling inside a windowless spaceship moving away from the sun at constant velocity. Galileo asserted that there are no mechanical experiments that can be made inside the rocket that will tell the occupants that the rocket is moving .
The question ``are we moving'' has no meaning unless we specify a reference frame (are we moving with respect to that star'' is meaningful). This fact, formulated in the 1600's remains very true today and is one of the cornerstones of Einstein's theories of relativity."
Marosz (me) ????
(it is understood that the apparatuses they use for these experiments move with them) ?
NOT EXIST C + V exist ONLY C !!!!
LIGHT = APPARATUSES THAT IS NOT MOVING WITH THEME !!!
Marosz
We  can use Laser and test  Idea that I described above
and I can  measure motion ( absolute Earth motion )
GALILLEO's natural fall down law
M---------------Earth
m
Galilleo Proved that mass M and m
will natural fall down on the Earth
in one and the same time !!!
Marosz in books we have bridge between light and gravitation
we can use universal equation ( Intensity of the signal )
below equation is important for light and for gravitation
http://3.bp.blogspot.com/-Lte2iJwLe5o/UOQ1UcAoLbI/AAAAAAAAAaM/TUzMDiW4NWU/s1600/lu.JPG
Marosz's adidtional paragraph to very old LAW !!!
m------------Earth------------m   >>> motion
If Exist motion ( constant motion also )
mass m left and m right will not touch the Earth
in one and the same time.
Why ?
Exist Different intensity of the gravitation  signal
that Earth is sending to mass m left and to mass m right
YOU CAN USE NATURAL FALL DOWN LAW TO PRODUCE ENEGY
author Maciej Marosz
Engineer & Inventor from POLAND
